Need help: vortec head swap backfires
Old Oct 3, 2021 | 09:02 AM
Starlifter's Avatar
Starlifter
Default Need help: vortec head swap backfires
I’ve got a modified ‘87 L-98.
Last thanksgiving one of my original heads cracked.
i replaced stock heads with vortec 906s w/ LS-6gm comp springs- longer spark plugs
scoggins Dickey tpi vortec intake
rebuilt the distributor
replaced the fuel control relay n a thermal fuse
git a new memcal (brain) for the comp from a pro in Canada (specifically for the engine mods)
im putting in new plug wires tomorrow
here is my current status
with the comp connected-
engine backfires hard immediately upon starting n I shut it down.
it surges n then a violent backfire.
with the comp disconnected- the engine idles, minor pops, engine shakes, if I step on gas, minor backfire. You can smell fuel faintly. It’s acting like fuel is not being burned, n it’s misfiring. I’ve tried timing at 6 deg adv- it shakes n backfires worse. Currently it’s at 0 deg advance.
TY
Gary
Old Oct 3, 2021 | 09:12 AM
Starlifter's Avatar
Starlifter
Default Datalog
FYI: I’ve never done this yet- but I have the gear to datalog. Is someone able to diagnose a datalog without the computer connected. That’s currently the only configuration where motor does not surge n violently backfire.
Old Oct 4, 2021 | 01:21 PM
ex-x-fire's Avatar
ex-x-fire
Double check the firing order.
Old Oct 4, 2021 | 02:06 PM
Starlifter's Avatar
Starlifter
Default Firing order
Firing order is good. 18436572 What’s weird is to set timing I’ve had to rotate distributor cap ccw a lot-the cap section of the electrical connections should be parallel with firewall, but it’s rotated towards front of engine- it’s pointing at no 7 spark plug. Not sure if I need to reset my distributor.
engine is missing- just put new distributor plug wires in/ it’s still missing.
if I touch throttle- engine pops n backfires ( without computer connected)
its worse with comp connected
Old Oct 4, 2021 | 02:25 PM
bjankuski's Avatar
bjankuski
Check your lifter preload, it sounds like it is set too tight.
Old Oct 4, 2021 | 06:57 PM
ex-x-fire's Avatar
ex-x-fire
Verify the timing mark at tdc, sometimes the balancer will slip causing the timing mark to not be even close when you check timing.
To Need help: vortec head swap backfires
