Brake Booster rod adjustable?
Old Oct 18, 2021 | 04:26 PM
TommyFox's Avatar
TommyFox
Default Brake Booster rod adjustable?
I replaced the brake booster on my 87 with the all metal one. Pedal isn't as hard and goes down farther to the floor than the stock one I replaced that was cracked. Didn't mess with the master with this install.
Is there an adjustment with the nut that engages the master?
Old Oct 18, 2021 | 04:34 PM
Krusty84's Avatar
Krusty84
Yes. There should be an adjustment nut on the tip of the rod. I had to adjust mine several times before I got it right when I replaced mine in my 84.
Old Oct 18, 2021 | 07:11 PM
TommyFox's Avatar
TommyFox
That's what I thought. Thanks!
Old Oct 18, 2021 | 08:06 PM
84 4+3's Avatar
84 4+3
Mine did as well. Think it's a quarter inch bolt on the one I used. I also made the actual adjustment tool (it exists). Looks like this and I just made it with a square and some tough cardboard with a wooden skewer through the ribs of the cardboard. Worked great and saved me a lot of unbolting of the MC. Two tries and it was good.
Old Oct 19, 2021 | 06:39 PM
TommyFox's Avatar
TommyFox
Ok fixed but now my brake light is on. Could be my parking brake sticking switch and a coincidence? lol
Old Oct 19, 2021 | 06:40 PM
84 4+3's Avatar
84 4+3
yea just pull back hard on the pedal and that should adjust the light switch
Old Oct 19, 2021 | 07:56 PM
TommyFox's Avatar
TommyFox
Well seems to be fine now. Finally got the brake system wrapped up.
To Brake Booster rod adjustable?
