AFR 190 and Hypertech fan switch...
Old Dec 23, 2002 | 01:14 AM
Kwik88's Avatar
Kwik88
Default AFR 190 and Hypertech fan switch...
I'm trying to put a Hypertech fan switch #4026 in a AFR 190. Problem is the the Hypertech is about a half inch longer than the stock switch and it bottoms out inside the water jacket before it tightens up. I called Hypertech and the guy said he's never heard that problem before. Any one ever run into this before? Or any ideas? Thanks.
Gary
Old Dec 23, 2002 | 01:16 PM
ralph's Avatar
ralph
Default Re: AFR 190 and Hypertech fan switch... (Kwik88)
i have a 180 fan switch. I don't know if it's a hyper tech or what, but i had no problems with it in my 190s.
Old Dec 23, 2002 | 01:21 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: AFR 190 and Hypertech fan switch... (ralph)
No problem here either :cheers: I would call AFR.
Old Dec 23, 2002 | 05:31 PM
2manyC4s's Avatar
2manyC4s
This happens sometimes. You can get a Standard Parts switch that will fit due to its small "nose". It also has the proper connector shape. It will turn your auxilary fan on ay about 210F which is fine. Then "force" your main fan on full time to keep engine temp near thermostat. You can do this with a ground wire or switch to ground on the control wire at fan relay.
Hope this helps.
Steve
To AFR 190 and Hypertech fan switch...
