OT: Question about Air Compressors
If I were to need more capacity down the road, are there "expansion" tanks that can be bought to add additional capacity to the compressor? Thanks in advance! :cheers:
My recommendation, based on the items you want to use with the compressor, is to buy the 80 gallon, 2-stage unit Lowe's has on sale now at $700. Sounds pricey, but it will do everything you want it ti do.
If you just want a small unit for general work, email me. I have a Sears 220V 20 gallon unit that I have used with some air tools, spray painting and a sand blaster which has been very productive for me. I've now outgrown it and need more volume for my heavy equipment needs.
The air nailer is another story though. Any 110V, 8 gallon, $250 special will run them. Got one of them too for the air nailer(s) but it can't provide the volume for the air tools (well maybe the small 3/8 ratchet).
Watch those horse power ratings too. a true HP is about 750 watts (about 7 amps at 110V and that doesn't include start current) Those 'developed' numbers they quote are meaningless as far as I'm concerned and mislead people.
The bigger compressor will also stop your buddys from borrowing it. :D
i would recommend it to anyone. The only thing is its a little loud, but you could do what I plan in doing. Since its portable, and easy to move. I just wheel it outside the garage door and close the door on the air line. Instantly quiet again! :cheers:
I am going to have to buy a 1/2" impact wrench for it (plus some other tools) in order to take my wheels off but I am hoping this unit can do the job...
Mike
[Modified by luvmy92, 9:27 AM 12/23/2002]
[Modified by Blue88, 8:43 AM 12/23/2002]
[Modified by weracemo, 2:55 PM 12/23/2002]
Pneumatic grinders, polishers, body files, large Dual Action (DA) sanders etc require a two stage, 220 volt compressor, 80 gallon tank. Consder this body shop quality. The 60 gallon tanks can be used if space limited. These larger units may require an additional electrical service disconnect, as in a 30 amp or better line. By running the right cable, you can wire up for an electrical welder. The electrical work could be significant if you go big. Better units will feature all cast iron compressors, US made electrcal motor. With larger units, can install filters and water speparators, etc.
On the medium side is the often mentioned Sears. If you grind or sand once a month, maybe, a marginal set up for larger air tools. For 3/8, 1/2, impact tools, air blower nozzles, drilling, etc, well within capabilities.
Light duty would be impulse air. Note however some units lower pressure (compressor on at 80 psi and compressor off at around 100) limits drop out of framing nailer service supply requirements. Namely, can drop to around 80 psi before compressor on. Typical nail guns need 90 psi to around 120. High pressure low volume. Have had this problem. These smaller units, good for supply air for nozzles, air chucks, impulse guns. Buying extra tanks, hookups, connectors, takes up a lot space and money.
Good luck.
dlmeyers 90 coupe zf 6 3 speed shocks
[Modified by dlmeyers, 10:01 AM 12/23/2002]
[Modified by Jim-K, 2:21 PM 12/23/2002]
