Stiff Shifter
Old Oct 20, 2021 | 03:59 AM
RedAnt1984's Avatar
RedAnt1984
Default Stiff Shifter
Yesterday on my 4+3 the shifter gained quite a bit of resistance moving it between all the gears. I do not really know if it was like that from take off or mid trip. But it happened over night. Day before it was loose as a goose and easy to move (it has always notched into each position nicely) It has 82k on it. Put about 4k since purchase. I had the trans fluid changed by the shop just as preventative maintenance maybe 1000 miles ago. Straight 80w. I do not think the fluid is relevant, but I just want to be sure this isn't a warning sign before I drive it an hour on Friday.
It did get down into the 30's here. It is warmer now but the stiffness remains.
Old Oct 20, 2021 | 04:26 AM
84 4+3's Avatar
84 4+3
The ignition lockout on mine occasionally binds and that causes it to feel "tight". Maybe work the key a few times and check that?
Old Oct 23, 2021 | 07:06 AM
RedAnt1984's Avatar
RedAnt1984
Interesting.
It did seem to help when it hit 70 outside again. So I guess it's not anything internal. I just can't picture anything servicable there, but yea it could be relevant to the reverse lock. That is somewhat intricate.
To Stiff Shifter
