C4 Starting issues
Old Oct 22, 2021 | 03:54 PM
Bradley's Avatar
Bradley
Default C4 Starting issues
94 A4 69,000 miles has been sitting awhile but typically started once every 6 to 8 weeks has failed to light up now. Engine turns over swiftly as battery has had a battery tender attached. Added some fresh premium fuel, pulled the air cleaner off the throttle body and gave it a spray of starting fluid resulting in a brief effort at turning over but then quickly dies. I suspect a possible fuel filter issue, possibly a fuel pump, but am looking for next steps to get my baby back on the road now that Las Vegas weather has cooled. Any ideas would be appreciated.
Old Oct 22, 2021 | 04:02 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
get a fuel pressure tester. verify you have fuel pressure. if you have fuel pressure then check injectors firing. Either from listening to them click click / tap tap tap while cranking or with noid light tester.
verify spark.
let us know.
