serving throttle bodies on 1984
I feel compelled to tell you, do NOT get the 'AC Delco rebuild kit'. I got mine on Rock Auto, it called itself a 'carburetor rebuild kit' and had parts I didn't even need, un-even amounts of parts, and gaskets/O Rings so cheap I was replacing them a week later when I realized fuel was just pouring over the injectors and flooding the motor. If it was honestly AC Delco brand, then it's just embarrassing. Maybe try one by Standard Motor Products or anyone else. I had to order new O Ring sets, ONLY Carquest has them through Advance, and 99% of stores will not stock them. I actually borrowed o Rings off my Cadillac to drive the car home without ruining the motor from over-fueling (it was a long drive).
You should be able to get to the regulator/accumulators without removing the throttle units from the intake. Which I would consider the parts actually worth servicing. Other than that, I suppose you're just not going to change the large bottom gaskets that mount it to the intake. That being said, I found it much easier to just sit it all on a bench on some carboard. There's an awful lot of small parts and screws and you'll want a large clean place to sit them. I lost my cruise throttle cable clip in the engine bay somewhere, and luckily that's all I lost.
I did not disconnect the linkage or anything like that, in case that's what you're worried about. You won't have to worry about 'syncing them up' after. However, to change some of those gaskets, you'll want the fuel lines out of the way, and the only way those were coming off the throttle bodies was on a bench where I could put a wrench on their properly and not round anything off.
