ls diff oil options
Old Oct 24, 2021 | 03:02 PM
Nilak's Avatar
Nilak
Default ls diff oil options
Hi,
I’m planning to use this 75w90 motul oil for my c4 ‘91 l98 differental:
https://www.motul.com/ro/en/products/gear-300-ls-75w90
other options could be :
https://www.motul.com/ro/en/products/gear-competition-75w140
this one I suppose would protect the gears and clutches well but would cause slightly higher temperatures and would rub some power
or:
https://www.ravenol.de/en/product/getriebeoel/getriebeoele-fur-schaltgetriebe-und-antriebsachsen/ravenol-dgl-sae-75w-85-gl-5-ls
this I think is similar to the first with marginal better fuel economy and power
which one do you think it’s suitable?
I use the car for a weekend driving but also a few trackdays (I usually run 1 power lap and one cooling slow lap)
thank you
Old Oct 24, 2021 | 04:15 PM
84 4+3's Avatar
84 4+3
The motul is more than adequate... I'd just reach out about the LS additive. Some companies still want you to add it on some cars while others don't... its a subject people fight over as much as oil but I'm not willing to get into it at the moment. Just question it.
Old Oct 24, 2021 | 04:27 PM
colter's Avatar
colter
I put in regular Valvoline 75w-90 gear oil that had limited slip additive. And in parking lots, I'd get some groaning. And so I had ordered some GM limited slip from Amazon, and a couple of clear empty squeeze bottles so I could pull out several ounces, and then squeeze in the limited slip additive.
I stuck with regular oil as I have read some say the synthetic gear oil can eat through the factory RTV. Though some say that's a myth. But I didn't want to take any chances as pulling the batwing would be expensive to have a shop do that to fix a leak.
Old Oct 24, 2021 | 04:37 PM
Nilak's Avatar
Nilak
Default thanks
the car is not listed by the oil manufacturer, I’ve just chosen it because it has the normal viscosity and it says it already contains LS additive.
Old Oct 24, 2021 | 04:48 PM
Nilak's Avatar
Nilak
Default is this addictive adequate?
I could only find 4x4 additives in my country
Old Oct 24, 2021 | 05:32 PM
84 4+3's Avatar
84 4+3
The slip lock is probably fine. Try it without the additive first. If it needs it then order and add it. You'll get chatter doing low speed turns if it needs it.
Old Oct 25, 2021 | 09:50 PM
Purple92's Avatar
Purple92
I run the Red Line 75 - 90 Oil. It supposedly does NOT need the Posi additive.
Old Oct 27, 2021 | 08:15 AM
Phobos84's Avatar
Phobos84
I put Red Line 75-90 in mine with the little bottle of Red Line LS additive. So far so good. But I probably didn't need the additive being that Red Line claims it already has it in it.
To ls diff oil options
