LT1 396 engine build
Old Nov 6, 2021 | 02:49 PM
krackenvette's Avatar
krackenvette
Sweet build. I need to look the piston company up, as I want ti rebuild/bore my 396LT1 out and put standard rings in it, and a smallet cam (duration is 230 to 240 int/exh).
Oil consumption has always been shitty with low tension rings.
But fun factor in my 93 Ruby is awesome.
Old Nov 7, 2021 | 10:16 AM
95wht6spd's Avatar
95wht6spd
What do you mean you saw some oil consumption when you opened up the engine? What did you see?
Old Nov 7, 2021 | 10:24 AM
tpi 421 vette's Avatar
tpi 421 vette
I could see on the pistons it was using oil. I changed the oil right before I started driving it. And it was a quart low after driving it 1000 miles. But it wasn't enough you could see clouds of oil coming out the tailpipe.
Old Nov 9, 2021 | 07:20 AM
88BlackZ-51's Avatar
88BlackZ-51
Looks good buddy!!! 👍
Old Nov 9, 2021 | 10:01 AM
ctmccloskey's Avatar
ctmccloskey
That is a really nice write up with photos! Your engine is beautiful and sooo clean. Very nice work!
Thank you for your time and effort!
Best Regards,
Chris
Old Nov 9, 2021 | 11:19 AM
krackenvette
What cat back, OEM?
Old Nov 9, 2021 | 01:26 PM
tpi 421 vette
Someone changed the exhaust on the car before I got it. It had manifolds with dual 3" pipes with a crossover pipe and some loud flowmaster mufflers. I put on headers and hi flow cats.Then I took off the flowmasters and put stock mufflers on it. It actually ran the same, but was alot quieter. So now it's headers, hi flow cats, dual 3" with a crossover, then it goes into the stock mufflers. Its kind of different, it's a pretty fast car, but its really pretty quiet. You just expect it to be louder for as fast as it is. The stock LT mufflers flow really well. I think the reason if people change them is they want a different look, or a different sound.
Old Nov 9, 2021 | 01:36 PM
krackenvette
I was contemplating putting the flowmaster system back on. I currently have no cats ( would like to put some on), 396LT1 and DRM 1 3/4 long tubes with oem cat back. Sounds good, imho, and at 54 years old, might be the right way to keep it..
Old Nov 9, 2021 | 05:56 PM
Red Dragon 79's Avatar
Red Dragon 79
Originally Posted by tpi 421 vette
Wow. That is gorgeous! love the wheel and the paint combo!
Old Nov 9, 2021 | 06:04 PM
tpi 421 vette
Thanks. Those are wheels that were on it when I bought it. They are C5 Z06 wheels with 295/35/18 tire on the rear. So a little more tire than the stock wheel size.
Old Nov 9, 2021 | 07:05 PM
glenx122's Avatar
glenx122
Sounds like a sewing machine under the hood but ready to rumble at the rear bumper.
Old Nov 9, 2021 | 08:00 PM
Shovels and Vettes's Avatar
Shovels and Vettes
Very nice Jim..
Old Nov 9, 2021 | 08:18 PM
  #33
tpi 421 vette
These cell phone videos never sound quite right compared to how they really sound. It does make the engine sound a little noisy, when its really quiet in real life with no valve train noise
Old Nov 10, 2021 | 12:33 PM
  #34
jayjones's Avatar
jayjones
Fuel pump?
Old Nov 10, 2021 | 12:51 PM
  #35
tpi 421 vette
Walbro 255 lph
Old Nov 10, 2021 | 03:15 PM
  #36
vader86's Avatar
vader86
Im using Bosch 30 lb injectors. PCM for less did the chip, and it feels really close. When it breaks in I'll put my wideband on it. But it has to be really close. Super responsive, and runs really nice. Pulls to 6000 rpm.
I have about 50 miles on it right now
I'm surprised it only took 30lb/hr, mine runs on 42s with the Walbro 255.
Old Nov 10, 2021 | 03:32 PM
  #37
rush0142's Avatar
rush0142
What mufflers are those?? And love the way those C5 Z06 wheels look!
My bad....just read your exhaust description
To LT1 396 engine build
Old Nov 10, 2021 | 03:38 PM
  #38
tpi 421 vette
I let PCM for less make the call on injector sizing since they are doing the tune. I told them the car will mainly be used at high elevation. So up here, we don't need as much injector since we're down on power because of the high DA
Old Nov 10, 2021 | 03:45 PM
  #39
tpi 421 vette
6000 to 8500ft DA is pretty common here. I think we are at about a 20% power loss from sealevel
Old Nov 10, 2021 | 08:24 PM
  #40
KSA Aaron's Avatar
KSA Aaron
You have done a very nice job on this 93.
When you get to a certain age (and power level), you no longer want the loud exhaust to show-off the power potential.
Kudos to you on another fine build.
