ultraseal valve cover gaskets
Old Nov 17, 2021 | 04:38 AM
Nilak's Avatar
Nilak
Default ultraseal valve cover gaskets
Hi,
I’m working on installing new valve cover gaskets and bought these ultraseal. they seem to be made of cork but have a polymer coat on both sides. Did anyone use such seal?
thanks
Old Nov 17, 2021 | 04:50 PM
Nilak's Avatar
Nilak
update
this is the driver side, I was leaking oil, under the gasket there was paint, not sure if it was suposed to be painted on the mating surface or to leave the bare metal. Then the paint was peeling off which could explain the oil leak. Otherwise the blue gasket looks ok. Should I reuse it or use the ultraseal?
Old Nov 17, 2021 | 07:57 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
i use hylomar and cork. but that is expensive.
i may try cork and a thin (!!) skim of permatex aviation gasket on the cork both sides.
my problem with rtv is the major pita for the next guy, which can alot of times be me. its quite possible cork will work with no coating, ive just never done it.
Old Nov 18, 2021 | 08:47 AM
FostersPerformance's Avatar
FostersPerformance
Should just use the rubber ones from factory. Make sure all the surfaces are clean and not oily (use brake cleaner or acetone). They get installed DRY, no adhesives or rtv or anything. Properly torqued they won't leak.
Old Nov 18, 2021 | 09:34 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Old Nov 18, 2021 | 11:12 AM
VikingTrad3r
Oil Producer
interesting i didnt know factory used rubber.
do u know what year that (ish) was? i remember discovering that my 85 had red rtv under the vcs and somewhere i read that 85 (maybe ironhead?) used rtv from factory?
when i tried the blue permatex silicone gasket it was too thick. Then i tried the thinner steel framed but with ribbed rubber and for whatever reason i couldnt get them to seal on the rounded perimeter walls of the 85’s ironhead. loath rtv....that was how i ended up with cork and hylomar. it was flexible so confirmed to the ironheads shape, and thin enough that i could use my factory bolts. the hylomar was a safeguard.
i do have an aluminum headed 90 im about to do as well...perhaps ill find the oem rubber underneath! cool
Old Nov 18, 2021 | 12:12 PM
FostersPerformance
I'm not sure when they started, but i thought it was 86 and up.. thats when the 1 piece seal started as well to dry up the SBC.....but im a boat guy,, and thats when they started with the better seals...
Old Nov 18, 2021 | 01:16 PM
383vett's Avatar
383vett
My 84 had cork. Now using reusable rubber.
Old Nov 18, 2021 | 03:12 PM
Nilak's Avatar
Nilak
These magnesium rocker covers seem problematic, while powder coating on the outside may work, on the inside rail the paint may be affected by engine oil. I saw GM made a polished aluminum set. I think I’ll just buy and install it.
Old Jan 15, 2022 | 04:29 AM
Nilak's Avatar
Nilak
I’ve installed aluminum rocker covers with the old silicone gaskets and they performed well so far. The leak before the swap was caused by swelling of paint between the gasket and metal because of magnesium corrosion, so the gaskets are still ok.
I ‘ll keep the old ones too and I’ll try to restore them.
To ultraseal valve cover gaskets
