Torque Spec for Upper A-arm Cross Shafts?
Old Nov 18, 2021 | 11:40 AM
LTxDave's Avatar
LTxDave
Default Torque Spec for Upper A-arm Cross Shafts?
I cannot find this in the FSM. Anyone know what they should be? One side was fairly tight and the other was not when I disassembled them.
Old Nov 18, 2021 | 11:56 AM
WVZR-1's Avatar
WVZR-1
I imagine it's NOT included in a FSM because bushings and shafts were never 'service parts' by GM SPO. Do any of the bushing suppliers supply assembly instructions and if they do, does it vary brand/product/material? There could be some interesting responses. What brand/product/material are your bushings or are the arms 'stock'?
Old Nov 18, 2021 | 02:16 PM
LTxDave's Avatar
LTxDave
Bushings are energy suspension poly. No instructions unless you count the packing slip. Stock arms and cross shafts.
Old Nov 18, 2021 | 05:11 PM
STEVEN13's Avatar
STEVEN13
Are you referring to the bolts/nuts that go to the chassis? If yes they are 37 FtLbs. (per FSM 1992).
Steve
Old Nov 18, 2021 | 05:34 PM
grandspt's Avatar
grandspt
This is from the Ridetech instructions, they are Delrin bushings installed (35-40 lb-ft). I used a bit of red Loctite on the threads too just to make sure they didn't back off. I know the factory used a thread locker that required a bit of heat to remove those nuts.
Old Nov 18, 2021 | 05:38 PM
WVZR-1's Avatar
WVZR-1
Certainly seems to be a reasonable #
Old Nov 18, 2021 | 07:15 PM
84 4+3's Avatar
84 4+3
I agree. Also, the range I found referenced in an old corvette central article matches those. It is only aluminum. I used 35 lb-ft.
Old Nov 18, 2021 | 08:31 PM
LTxDave's Avatar
LTxDave
Steven13, I found that value in the manual, but it's the big nuts on the end that I am looking for.
​​​​​​Thanks, guys! I appreciate it!
Old Nov 20, 2021 | 09:22 AM
jmgtp's Avatar
jmgtp
The bolts that secure the cross shaft to the chassis or the giant nuts on the ends of the cross shaft that secure the control arm? If the latter, not in the FSM. I went with 80 ft lbs and Loctite. Almost 5 years, haven’t thought about it since.
https://www.corvetteforum.com/forums...verhaul-5.html
^^See post 81
Old Nov 22, 2021 | 12:10 AM
MatthewMiller's Avatar
MatthewMiller
I attached the Energy Suspension instructions I had. But you can see they just say "tighten nuts to factory specs"...which don't exist. So thanks for nothing, ES! There are a couple factors at play. First, those cross shafts are aluminum so you can't torque them anywhere near as tight as a steel bolt that size. Second, your goal in torquing the nuts is to capture the inner metal sleeve with the washer so that when the control arm pivots, the poly bushing rotates on that inner sleeve (and not within the outer sleeve). So I would try to tighten the nuts to 30lbs and see if you get that desired rotation. Then adjust the torque as necessary to get that accomplished.
File Type: pdf
Old Nov 23, 2021 | 06:21 AM
krackenvette's Avatar
krackenvette
Years ago, did VB&P poly graphite type bushings. I did 35#'s using a calibrated torque wrench, per research back then... I used red loctite too. Only one has backed off. I put a sharpie mark on it..
Old Nov 23, 2021 | 09:33 AM
NavAir's Avatar
NavAir
If you know, or can determine the fastener size, you can default to the standard recommended torque value:
Old Nov 23, 2021 | 11:50 AM
WVZR-1's Avatar
WVZR-1
That I don't believe could/should be used for the OP's question regarding the nut's on the control arm shafts. For 'most all other' fasteners it could be considered 'appropriate' BUT always check for a more appropriate specification for specific applications.
Old Nov 23, 2021 | 06:57 PM
MatthewMiller
No! Again, these cross shafts are made of aluminum instead of the various grades of steel that typical fasteners use. If you default to the standard fastener size torque spec...well, have fun shopping for new cross shafts.
Old Nov 23, 2021 | 07:08 PM
NavAir's Avatar
NavAir
Aluminum? Really? I know that the control arms are forged aluminum, but the shafts? I've seen them dozens of times working on the car, but always assumed that they were plated steel. It is interesting that there is no published, official torque value for them though. My experience is that if a fastener requires a torque value other than the normal value for its size or a special torque procedure such as torque-to-yield, that is highlighted prominently in the service manual.
Old Nov 23, 2021 | 07:21 PM
krackenvette
As posted about 15 years ago, its 2024 Aluminium, and Non Serviceable via GM. Buy the whole arm, and deal with it.
Or, use what most people have come to agree on, around 35 ft/lbs.
Global West said 10 ft/lbs for their bushings.
Best I could find for a recommended calculation is this. Its a 15mm bolt, 30 mm nut correct?
They dont have the specific material 2024, but two aluminums come up 6061 is what I chose. 40.88 ft/lbs
https://www.extreme-bolt.com/fastener-torque-specs.html
And if you are feeling froggy, try Nasas recommendation, which does have this metal in there.
https://ntrs.nasa.gov/api/citations/...0170003491.pdf
Old Nov 23, 2021 | 07:36 PM
NavAir's Avatar
NavAir
Thanks for the citations. The NASA one is especially interesting. I didn't ask the original question, but I was surprised that there wasn't a published spec for the torque value in the service manual. After all, Chevy must know what torque they set their nut drivers to on the assembly line...
To Torque Spec for Upper A-arm Cross Shafts?
Old Nov 23, 2021 | 07:54 PM
krackenvette
Global West bushing was 10ft/lbs per instructions.
https://lib.store.yahoo.net/lib/yhst...g-kit-1059.pdf
Ride Tech says 37ft/lbs
https://www.ridetech.com/instructions/11569500.pdf
I guess the propertys of the bushings determine some of the torque to to keep from binding up?
Old Nov 23, 2021 | 08:24 PM
WVZR-1's Avatar
WVZR-1
Those shafts are NOT installed on the 'assembly line' in BGR - the control arms arrive assembled and 'ready to install'!!!
Old Nov 23, 2021 | 08:26 PM
krackenvette
^ yes, they are pre assembled at some plant that makes them.
Thats why most FSM have no torque specs as the entire arm is a serviceable item.
Of course you can do the ball joints.
