dana 44 gear install
Old Nov 24, 2021 | 09:10 PM
JCSZ51's Avatar
JCSZ51
Cruise-In IX Veteran
Default dana 44 gear install
Question for those who've dove into a dana 44. I'm in the process of installing 4:10s in one of my zr1s and found an interesting scenario. The stock pinion had zero shims under the bearing.... I've done a bunch of rearends before but this is my first dana 44, I've never seen a rear not have shims under the pinion. Rear was stock, unopened and made zero noise. Is this common?
Old Nov 24, 2021 | 09:26 PM
WVZR-1's Avatar
WVZR-1
That is odd I believe. Pattern is what you'd expect for the miles? Is your new gear set a 'crush sleeve', a collar or you're expected to do shims. What's the information on the ring gear that you removed? Is the 4.10 a 216mm ring gear or a 226mm ring gear?
Old Nov 24, 2021 | 09:38 PM
JCSZ51's Avatar
JCSZ51
It is odd, the wear pattern is perfect. New gear set is a mopar unit with the crush sleeve.
Old Nov 24, 2021 | 09:42 PM
WVZR-1's Avatar
WVZR-1
It's important to know 216mm or 226mm before you start! Part # of the MoPar Set?
Old Nov 24, 2021 | 11:49 PM
JCSZ51's Avatar
JCSZ51
p5007043 the correct one
Old Nov 25, 2021 | 04:14 AM
WVZR-1's Avatar
WVZR-1
That I believe is a 216mm gear set with the 3/8 ring gear bolts. It costs nothing to 'measure' and confirm. If perhaps it's 226mm it will still work but there will be massaging required.
Old Nov 25, 2021 | 06:23 AM
Kilobuck84's Avatar
Kilobuck84
Maybe they're under the race instead of behind the bearing? Sometimes that's done to keep the shims from sqeezing out under high loads.
Old Nov 25, 2021 | 10:31 AM
JCSZ51's Avatar
JCSZ51
It's 216
Old Nov 25, 2021 | 01:05 PM
rklessdriver's Avatar
rklessdriver
Certainly interesting.... I've never seen one like that and have taken apart/setup a bunch. Things happen with tolerance stack and obviously they got a pinion with a high shoulder and a housing with a shallow rear bearing race pocket that managed to just work out....
Will
To dana 44 gear install
