There are arrows on the frame rail close to both the front and back wheels where the steel frame and body panel allow the “u” in the jack to lift against the steel rail. Too often you will see damage to either the floor pan or body panel because the jack was placed incorrectly. If you reach between that six inch space where the arrows are you will be able to feel the steel rail. That is what lifts the car.
It states to put the jack between the arrows on the body but....thats on the curve of the body flange. Whats the deal with that??
My son has a 1990 and it has often struck me that how to jack the car up seemed like an afterthought in the design. The arrows on the body it seems are just to help you position the jack with respect to fore/aft- fitting it somewhere between them. The actualy frame is about an inch inboard toward the center of the car and the jack fits on the frame pinch weld. When I use a trolley jack, I put it underneat the body as well and since that's flush with the frame pinch weld, it doesn't seem to cause any issues. His car shows damage from former owners jacking it up too far inboard and messing up the floor pan. In addition, I'm unnerved by how closely some of the brake lines run behind those jacking points, but thankfully it hasn't been a problem so far... fingers crossed.
Google this " how to read forum posts". I have the owners manual, says to align arrows, mine does not align with the pinch weld. So go google that!
Can you shoot a pic of what's not lining up?
You can jack at ANY point along the pinch welded seem, from the front of the rocker rail, to right in front of the rear wheel, and it will all work, "fine". In fact, if you jack about 6" rearward of the side view mirror, the front and rear wheels will lift about evenly, making it easy to install two jack stands at the jacking points at the same height, and at the same time....then go around to the other side, do the same there. You can have the car safely on 4 stands in about....4 minutes.
No, that is totally typical. The "lip" on the fiberglass rocker trim/cover is only there to hide the pinch weld/seam. It's not meant to be jacked on in anyway and contributes nothing to the strength of the car or the pinch weld. The pinch weld is super strong and handles the loads of jacking the car with ease.
THUS...when jacking, you simply want to make sure that your jack pad isn't applying enough force to the fiberglass rocker trim as to crack it. In theory, the trim should be just a few mm higher than the bottom of the pinch weld so the jack pad won't touch the trim, but in reality, cars vary....'80's GM QC here.
