Ignition Actuator Rod
Old Dec 4, 2021 | 04:50 PM
bp308's Avatar
bp308
Default Ignition Actuator Rod
I replaced the ignition switch on my 91 Coupe. In the process, I somehow managed to disconnect the actuator rod from the locking assy. I cannot get the column covers out of the way to try to figure out how to reconnect it. Any suggestions? The easier the better of course.
Old Dec 5, 2021 | 10:14 PM
Kevova's Avatar
Kevova
You need to take column apart to where ignition cylinder is out of housing. There are 3 screws than hold housing on knuckle.
exploded illustration maybe helpful.
YouTube videos related to.loose GM tilt column will cover your issue; during the disassembly and reassembly process.
Old Dec 6, 2021 | 06:53 AM
bp308's Avatar
bp308
Thanks Kevova
To Ignition Actuator Rod
