85 maf power relay
Old Dec 8, 2021 | 10:06 PM
johnfin's Avatar
johnfin
Default 85 maf power relay
Where is it located?
Old Dec 9, 2021 | 06:38 PM
1985 Vette's Avatar
1985 Vette
1985 Corvettes have a one year only MAF Burnoff module which is mounted behind the breadbox. Not easy to get to. When I replaced mine, I mounted it lower for easier access in the future.
1986-1989 Corvettes have relays easily located behind the battery.
Here are some pages from my 1985 Factory Service manual.
Are you having codes/ issues with your MAF?
Old Dec 9, 2021 | 08:16 PM
johnfin's Avatar
johnfin
Default Location
I know where the module is, need the location of relay.
https://www.corvettemods.com/C4-Corv...iABEgIdXvD_BwE
Old Dec 9, 2021 | 08:20 PM
WVZR-1's Avatar
WVZR-1
There AIN'T ONE - read your supplied link one more time!!!
Old Dec 9, 2021 | 08:42 PM
1985 Vette's Avatar
1985 Vette
The 85 Corvette (and TPI Camaros and Firebirds) have the one year only MAF Burnoff Module.
There are no MAF relays in 1985.
1986-1989 Corvettes have relays instead of the MAF Burnoff Module. The relays replaced the Burnoff Module.
FYI: I would avoid Corvette Mods. I had a very bad experience with them. Many Forum members have had bad experiences as well. I encourage you to do some searches on the forum.
Old Dec 10, 2021 | 07:15 AM
johnfin's Avatar
johnfin
Default Harness
The original harness has a relay called MAF POWER on it. Its just been loosened and detached from the engine compartment. Its tethered with the fuel pump relay.
Old Dec 10, 2021 | 08:20 AM
WVZR-1's Avatar
WVZR-1
What are the wire colors on the connector that you say has that 'relay' plugged into?
***The last time you asked about those relays I mentioned posting part #'s and 'wire colors' - you didn't!
***Your thread: https://www.corvetteforum.com/forums...post1604420487
You have the wiring diagrams they're there!
If it's actually an '85 harness this I believe might be correct!
Old Dec 11, 2021 | 04:17 PM
snlshow's Avatar
snlshow
Agreed! Avoid corvette mods
To 85 maf power relay
