Side impact safety concern for tall C4 drivers
The other day I hit some large bumps in the road going pretty fast and banged my head on the top. No big deal, but after thinking about how limited the headroom is, what would happen if the car was hit from the side? Seems to me that a tall person's head would hit the hard steel framework of the roof panel. If hit hard at all, the resulting contact of a person's head against the roof panel's structure could seriously injure or kill them!
I was just watching a program on vehicle safety a while back and the recent emphasis on side impact air bags. The program stated that the reason they are so important is that it takes very little side-to-side movement of the brain inside the skull for an injury to cause death. I love my Corvette and wouldn't consider not driving it because of this, but maybe there is something that can be done that would minimize the risk of this type of injury in a collision?
I guess the reason for this rather depressing post is to make other tall drivers aware of the risk and to brainstorm ideas to make our cars safer. I'm considering using some type of foam tape on my roof in this area, but that wouldn't look very good and probably isn't dense enough to do any good.
I'm surprised Mid-America, Ecklers, Corvette Central, and the others haven't come up with something to address this, they seem to have every other accessory you could possibly want (and many more you don't) for a Corvette!
[Modified by vetracer, 11:30 PM 12/26/2002]
then i bolted two metal straps front/back on the bottom seat bolts
i drilled a hole in the right spot (4) through the straps, and placed a bolt going upward from that. To level it out, i put another bolt 3/4 the way down the back one, half the way down the front one, wtih a washer on top. sat the seat on that, bolted it down. PLENTY of room now/
Keeps me on my toes at least, lol. Be careful out there :eek:
[Modified by JCAIRE2, 6:22 PM 12/26/2002]
One thing I learned is that it isn't that easy to replace. I ended up taking the seat out and removing the side panel from the console, as the switch is somewhat permanently connected to a 2' long harness.
Once I get the part and put it in it should be much more enjoyable to drive. Then again, it was kinda nice to be able to keep my head from rolling from side to side in the turns just by trying to sit up straight!
Hopefully it will put my head in a better position in relation to the structural steel support for the top. As it was before it wouldn't take much of a side hit to split my melon pretty good. It would still be interesting to hear if anyone else has head clearance issues.
[Modified by vetracer, 11:32 PM 12/26/2002]
Im 6'6" and do it the acrylic top when i go over a big bump at speed, no other times though.
[Modified by NightRyder, 12:12 AM 12/27/2002]
The C4 door design, except for the '96, doesn't meet current Federal side-impact standards. You can read about it in ACAR. The '96 cars have doors that are heavier due to a semi-successful attempt to add reinforcing bars.
What to do about it??? I will probably try to find some rollbar padding and fit it to the back and may side to at least offer a little cushion. I am definitely interested in some way of lowering the seat some more. My problem is the wife will drive it occasionally and she in only 5'2", so the seat would have to move. I probably need to look at different seats as the head rest hits me right below the neck and between my shoulder blades.
I keep 2 things in mind on the road, the first is defensive driving, many drivers avoid being close to corvettes out of courtesy for those who appreciate cars. Then there are the other idiots you need to avoid at all costs, as they are the poster children for the right to abortion.
The other item, is the fact that these cars are made of glass and they will fall apart rather rapidly on impact. As careful as you think you can be, there is always the potential for something out of your control. If it is serious, just get the heck out, if there is fire (been in this) roll on the asphault. Most of the time you have perhaps 1 maybe 2 seconds to react, as you see it coming. Duck your head toward the center console and then get out, even if the car is still rolling. Grab your passenger by the back of the neck and throw their body toward the center as well. If you're unconscious, then you might be toast.
Just watch out for the other guy, if you can. Been rear-ended in this thing 3 times which is one of the unavoidable situations. Other drivers just don't think.
Seat belt will help some, I'm thinking of adding a harness anyway for autocross (I take the top off to race), that should help more than standard lap/shoulder combination.
Youse takes your chances and youse toss the dice.
