Seeking front harness info
Old Dec 29, 2021 | 04:50 PM
ajp01's Avatar
ajp01
That is exactly right. Straight down from the blue arrow you can see the black plastic vacuum line arching off to the firewall / harness. The Tee fitting has the male end and just to the left of that is the one-way vacuum check valve with the hose going left to the upper TPI plenum (vacuum source). From the bottom of the Tee that hose goes to the fuel evaporative emissions hardware and cruise control vacuum lines I believe.
Old Dec 29, 2021 | 07:21 PM
Yguy's Avatar
Yguy
I just went out and took a look at it. Pretty sure it’s only been disconnected at the plenum. The other connections seem intact.
Old Dec 29, 2021 | 09:06 PM
ajp01's Avatar
ajp01
Good. Since that plastic vacuum line heads through the firewall with the main harness, you'll need to take care to notice where it attaches on the cabin side and reattach there once the new harness is in.
Old Dec 30, 2021 | 02:52 AM
Yguy's Avatar
Yguy
Again, this is on an 89 model.
Regarding the timing control disconnect, I’ve got one end that looks like it goes to the right side, but I can’t remember if I hid the other side plug inside the flex conduit that goes to the left with the harness that’s routed past the wiper motor, or if it’s hidden in the one that routes around the big A/C housing. If I had to guess, I’d think it’s in the one going past the wiper motor.
ALSO, how in the heck do I get the harness retainer apart? I’ve got it loose from the firewall, but it refused to come apart. Do I need to hit it with heat to separate it?
Old Dec 30, 2021 | 09:04 AM
WVZR-1's Avatar
WVZR-1
I wouldn't worry about that presently. Even if you're anticipating a splice repair I'd think it best be done on a 'bench' out of the car. I sent you an email regarding price and moving forward if you'd like mine.
Old Dec 31, 2021 | 02:44 PM
Yguy's Avatar
Yguy
WVZR-1
Sent a couple emails your way
Old Dec 31, 2021 | 02:46 PM
WVZR-1's Avatar
WVZR-1
WVZR-1
I got them - I'll be back to you!
