C4 406 SBC swap question
Old Dec 29, 2021 | 06:05 PM
Ispy67's Avatar
Ispy67
Navigator
Default C4 406 SBC swap question
I have a question for those who have installed a SBC 400 in a C4. I have an 87 convertible that I plan on swapping a mild performance 406 into. This is an externally balanced motor with the larger harmonic balancer and 168 tooth flex plate. Are there any mods required to the crossmember to get the larger harmonic balancer to work? I know the 700R4 dust cover will need to be modded with the larger flex plate. Any help would be appreciated. Trying to cover all the bases before I yank the old L98.
Old Dec 29, 2021 | 06:24 PM
cv67's Avatar
cv67
St. Jude Donor '05
Ought to get an answer pretty quickly here lots of traffic.
What else are you gonna do to the 400? Came too close to installing one in an 89 I had but a ZR-1 found me.
Wish I did it...they make so much torque!
Old Dec 29, 2021 | 07:02 PM
Ispy67's Avatar
Ispy67
Navigator
The 406 has 5.7 rods with speed pro Hyper 10:5 to 1 pistons. A Lunati 262/268 cam with 1.5 roller rockers. Skip White NKB 200 aluminum angle plug heads in 64cc. SLP big mouth intake with ported SLP runners and 58mm throttle body. Ported stock L98 headers with a free flowing "catless" exhaust. Car does have a dana 36 with a 3:55 ratio. Motor is all built now I'm worried about the 400's harmonic balancer? I think I'll be ok?
Old Dec 29, 2021 | 09:36 PM
tpi 421 vette's Avatar
tpi 421 vette
I think Pioneer makes a 6.5" external balanced damper that will clear the crossmember. There are other manufacturers that also make a small external balance damper
Old Dec 29, 2021 | 10:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
Headers would really add to what you got, those manifolds are super restrictive.
Old Dec 29, 2021 | 10:12 PM
Ispy67's Avatar
Ispy67
Navigator
Thanks, I just bought a assault racing 6.75" 400 sbc dampner. I never knew until today they made it! That solves that issue. In regards to the headers, does anybody have any experience with ones that fit well?
Old Dec 30, 2021 | 08:51 AM
FostersPerformance's Avatar
FostersPerformance
I have a 8" balancer on my 383 in my 88. Youve got about an inch maybe of clearance.
Old Dec 30, 2021 | 09:07 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No kidding? That's good to know!
You can run the small 158 tooth flex plate, FYI.
Old Dec 30, 2021 | 10:50 AM
vader86's Avatar
vader86
Old Dec 30, 2021 | 02:07 PM
cv67's Avatar
cv67
St. Jude Donor '05
Have a brand new set of 1-3/4" shorties, custom made if you dont want longtubes. Not gonna be using them
Asking cost, 5 bones plus ship
Longtubes get the best results though esp if youre going to be running dual exhaust
Old Dec 30, 2021 | 05:41 PM
Ispy67's Avatar
Ispy67
Navigator
They make a 400 SBC flex plate in 153 tooth? Never saw one?
Old Dec 30, 2021 | 06:13 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Well that's a good question. I was using a flywheel (stick shift).
It turns out that they DO MAKE 'EM
Old Dec 30, 2021 | 07:35 PM
cv67's Avatar
cv67
St. Jude Donor '05
TCI, nice. Figured at least Pioneer would make them
400 is a killer choice imo for a low rpm tall geared c4. Improve the intake, exhaust it will roast rubber at any time.
DId CFI-EFI ever get his in or was it a 350 still?
If I Could afford another C4 thats the route Id certainly go. Good heads, small cam and make it sleepy (quiet)
Old Dec 30, 2021 | 08:05 PM
383vett's Avatar
383vett
I am running ARH stepped 1 3/4" to 1 7/8" headers on my 406. They are worth 1.5 tenths over Hooker 1 3/4" headers in the quarter. With the bigger cubes, better heads and breathing, I would look at a miniram for your car. My motor is internally balanced so I can run a normal sized, neutral balanced balancer and flexplate.
Old Dec 30, 2021 | 08:15 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Nope. I have it now...got it when he passed. And it's going in my '92.....some day.....
Old Dec 31, 2021 | 05:26 PM
RWDsmoke's Avatar
RWDsmoke
When I installed the 350 vortec motor form a 96 truck into my 86, the 8 " balancer that came on that motor hit the crossmember before it was fully lowered into position. I replaced it with 6.75" from Summit Racing and I still can barely get a finger between the balancer and the crossmember. I would think your 87 would be the same as my 86. Things changed in that area in 88. I thought about notching the crossmember but with the front spring in there I decided not to go that route. Changing the damper was much easier.
To C4 406 SBC swap question
