'87-'88 Stock Cam specs?
Old Dec 26, 2002 | 07:58 PM
GRX's Avatar
GRX
Default '87-'88 Stock Cam specs?
Does anyone know these? TIA :thumbs:
Old Dec 26, 2002 | 09:23 PM
BBA's Avatar
BBA
Default Re: '87-'88 Stock Cam specs? (GRX)
I saw them once...it was like 204º/206º and around .430" valve lift, very mild cam.
Old Dec 26, 2002 | 09:25 PM
GRX's Avatar
GRX
Default Re: '87-'88 Stock Cam specs? (BBA)
Thanks. Sounds very much like the '85 cam.
Old Dec 26, 2002 | 10:51 PM
vader86's Avatar
vader86
All I have is specs on the '88 cam with 1.5:1 rockers:
Lift=.410"/.423" (int/exh),
Dur=211/219 deg @.050” (int/exh),
LSA=117deg.
the 85-86 cam:
Duration @ 0.050 202/206
Lift with 1.5 R 403/415
Lobe Seperation 114.5
Old Dec 28, 2002 | 05:44 PM
GRX's Avatar
GRX
Default Re: '87-'88 Stock Cam specs? (vader86)
Vader, are you sure those are STOCK specs? Wow, I never realized that the 88s had that much duration???? :confused:
Old Dec 28, 2002 | 05:58 PM
dgoodhue's Avatar
dgoodhue
I honestly don't think a stock 88 cam has that much duration. The 87 has different cam than a 88, same specs as the 85-86 but as a hydrualic roller cam (as oposed to hydraulic flat tappet)
Old Dec 28, 2002 | 06:28 PM
dgoodhue's Avatar
dgoodhue
Default Re: '87-'88 Stock Cam specs? (dgoodhue)
BTW On this page the lift numbers are listed http://www.corvetteactioncenter.com/....php?qstId=169
w/1.5 R these compute to a lift of .415/.430
On this f-body page http://www.f-body.org/tech/tech.htm#ThirdGen
The 88-89 f-body cam is listed as .415/.430 207/213 (@0.050) w/117 lobe seperation.
If I was a betting man, I would guess GM used the same cam for 88 and 89 F and Y bodies and since the lift numbes match up.
[Modified by dgoodhue, 6:35 PM 12/28/2002]
Old Dec 28, 2002 | 08:39 PM
vader86's Avatar
vader86
The numbers came from 65Z01, he stated that they come from his 88 Helm Manual. (if i remember his words correctly)
[Modified by vader86, 8:43 PM 12/28/2002]
Old Dec 28, 2002 | 08:41 PM
vader86's Avatar
vader86
Its not a direct conversion remember, if you have a 202/202 flat tappet cam, its not the same as a 202/202 hydraulic roller.
Old Dec 28, 2002 | 11:54 PM
dgoodhue's Avatar
dgoodhue
The first link is to the actual GM TSB correcting the factory service manual, so I doubt the that is wrong. The lift numbers would be 415/430. The 410/423 lift numbers look to be from 305 L69 and Crossfire motors.
I am little confuse by this statement, but anyways. The 85-86 cam and 87 cam share physical specs but are two different part numbers and two different pieces. I realize the difference in flat area of a flat tappet reacts to camshaft lobe as oposed to the round roller of hydraulic roller.
Old Dec 29, 2002 | 12:02 AM
dgoodhue's Avatar
dgoodhue
I would like to know where he got the duration and cam lobe seperation specs in the helms service manual, as I can't find them in my manual.
Old Dec 29, 2002 | 12:11 AM
vader86's Avatar
vader86
Dont debate it with me, run a search dude, hes posted it on here several times. I just copied his data.
To '87-'88 Stock Cam specs?
