1989 MAF sensor
Old Jan 1, 2022 | 07:21 PM
larryfs's Avatar
larryfs
Default 1989 MAF sensor
Who makes a 1989 MAF sensor with the proper burn-off section.
I tried chinese garbage at autozone, and they throw a code 36. Is OEM still available ?
Old Jan 1, 2022 | 07:29 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Go to junkyard. Second hand parts
Old Jan 1, 2022 | 07:54 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Current MAFs will throw code 36 because they don't implement the burn circuit. They don't requires the cleaning, unlike the originals (should use MAF cleaner annually instead).
Options:
- Find a salvage, as mentioned.
- Buy a really expensive ($600?) MAF that is to all the original specs, including the burn circuit.
- Have someone disable code 36 in the ECM MEMCAL. This should be about $100, but varies depending on who and/or if they replace the original EPROM with a Flash replacement (a good idea).
I kept with third party and had code 36 disabled, works fine for my '87.
Old Jan 1, 2022 | 08:06 PM
larryfs's Avatar
larryfs
No junk yard around here will have any 1989 cars available. They are all crushed already.
Old Jan 1, 2022 | 08:10 PM
*89x2*'s Avatar
*89x2*
Try the online salvage yards, or even eBay, Lots of options for good used parts.
I got an 89 MAF and ECM spare 5 or 6 months ago at my local junk yard
Old Jan 1, 2022 | 08:15 PM
TommyFox's Avatar
TommyFox
I got a used Bosch 89 from Mirrock Corvette parts.
To 1989 MAF sensor
