MAF sensor
Old Jan 4, 2022 | 11:25 AM
Growth 3's Avatar
Growth 3
Default MAF sensor
In the process of rebuilding my 89 motor and need to replace the MAF sensor. Is there a brand that works better with a slightly modified engine? Thanks
Old Jan 4, 2022 | 11:44 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
YES !!!! Your MAF is a 'hot wire' style - now obsolete. Slot style is now what you want BUT requires an adapt to your tune ........
Old Jan 4, 2022 | 12:20 PM
Growth 3's Avatar
Growth 3
OK but what brand is the best for my motor?
Old Jan 4, 2022 | 12:21 PM
vader86's Avatar
vader86
You do not have to, OEM is fine.
Old Jan 4, 2022 | 03:19 PM
ctmccloskey's Avatar
ctmccloskey
I would stick with the original style myself as well. Like Vader86 suggested "you do not have To, OEM is fine". That has been my experience as well. I would just be sure to replace the two relays used on the MAF circuit to be sure that all functions like it is supposed to.
Upgrading the MAF might be more work than it is worth in the long run. I bought a new MAF after buying the C4 and pulled the original and stored it away. As long as the relays work the MAF should work for a long time, it has for me at least. I clean mine and make sure it stays clean by spraying it with the MAF sensor cleaning spray and letting it dry.
Before I would switch to a new Slot style MAF I would convert the engine to use a MAP sensor instead.
Your new engine will work just fine on the MAF like the factory used. Enjoy that new engine and stay healthy!
Old Jan 4, 2022 | 06:35 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Maf
I would try changing the relays before i purchased a MAF.
you might find that they are really the problem.
Old Jan 4, 2022 | 07:25 PM
Growth 3's Avatar
Growth 3
The reason I need to change it is that's it's the original and the connector is cracked
Old Jan 4, 2022 | 08:07 PM
funtoy's Avatar
funtoy
Hello I have two MAF's for sale that I no longer need. One is used and worked great and the other is brand new and was my backup just in case.
Old Jan 4, 2022 | 09:05 PM
tequilaboy's Avatar
tequilaboy
I'd get this one: https://www.topflightautomotive.com/...low-sensor-gm/
or: https://www.originalgmparts.com/oem-...ensor-10055877
Note: some sources indicate that this sensor has been discontinued
To MAF sensor
