Battery Drain - Need Advice!
Old Jan 8, 2022 | 04:07 PM
WhiteC1's Avatar
WhiteC1
Default Battery Drain - Need Advice!
I’ve had my 95 in the garage working on installing a new stereo. After it was done, I went to start the car, and the battery was too low to crank it. So, I charged it up overnight, and all is well. However, there didn’t seem to be a reason for the battery to be so low, so quickly (it’s a 2019 battery). I decided to try to figure out where the drain was, so I put my VOM I’m live with the disconnected negative cable, and it registers a steady 3.7 amp draw. This seems excessive, and certainly enough to drain the battery in a few weeks. I waited several minutes with the doors closed, to make sure it wasn’t something needing to ‘time out’. The draw stayed the same. So, I disconnected every fuse, in all three fuse panels, one by one, and the draw never changed. What am I doing wrong? Somebody with some electrical skills please help me out!
Thanks,
John
Old Jan 8, 2022 | 05:41 PM
jpipx's Avatar
jpipx
I have the same issue on both of my cars, both 1995 model year. I've seen other posts where owners have tried to track down the source of this parasitic current draw with different limited results. Some say it's the hood lights staying on due to the mercury switches, some say it's the security system or proximity system. I've stopped searching for the exact reason... during the season I usually run my cars enough to keep the battery charged and in the winter I keep them both on a battery maintainer. Hope you have better luck than I had.
Old Jan 8, 2022 | 06:45 PM
JimArn's Avatar
JimArn
I've heard of a bad diode in the alternator draining the battery. Here's a quote from this web site: https://itstillruns.com/can-alternat...y-7605315.html
"Bad Diode
A malfunctioning diode in the alternator can create a parasitic drain on a car's battery. Diodes should allow current to pass in only one direction, but a bad diode will keep the charging circuit open even when the engine in not running, allowing the battery to go dead. This often happens overnight."
Check for current flow between the battery and alternator with key off.
Old Jan 8, 2022 | 07:07 PM
jazfe's Avatar
jazfe
I found a cut on my starter cable at one of the clamps that hold the cable to the back of the engine. Now that was a head scratcher for awhile.
Old Jan 9, 2022 | 02:55 PM
JimArn's Avatar
JimArn
Originally Posted by WhiteC1
I disconnected the wire at the alternator and put my ammeter in line between the wire and the alternator post. When I hooked up the battery, I show 2.7 amps. Does this sound like a bad diode in the alternator?
John
John,
Yes, I think you found the problem.
Jim
Old Jan 9, 2022 | 03:21 PM
WhiteC1's Avatar
WhiteC1
Actually, Jim, I’ve determined that I’m an idiot… I had my meter cables plugged into the wrong place for measuring amps. When I switched it, I only have about 25 milliamps draw at the battery with everything off. I guess I need to double check my battery to make sure it’s not low on water, or some other reason why it doesn’t seem to be holding a charge very long. Thanks to all for trying to help me solve an issue I didn’t have…
John
Old Jan 9, 2022 | 03:32 PM
JimArn's Avatar
JimArn
John
Been there.
To Battery Drain - Need Advice!
