1986 Corvette MAF
Old Jan 12, 2022 | 06:54 PM
ALG's Avatar
ALG
Default 1986 Corvette MAF
I am in need of a MAF for my 1986 vert. Can anyone help me with the part number, where to obtain one, and brand?
Thanks in advance,
Old Jan 12, 2022 | 07:09 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Maf
Just go buy one at O’reilly’s or autozone.
T hey wkll have one that’s lifetime warranty and u never have to buy another one
Old Jan 14, 2022 | 12:29 PM
1985 Vette's Avatar
1985 Vette
Thanks in advance,
The GM part # for a 1986-1987 MAF sensor is 14094712 (see below).
GM quit making them long ago, Your best bet is to get a reman unit from Blue Streak Electronics. http://bsecorp.com/catalog/
BSE lists the MF4712 part# as compatible for 1986-1989 Corvettes.
You can buy these BSE units from Oreilly or Autozone. Maybe RockAuto.
I bought a rebuilt BSE MAF unit from Autozone 2 years ago for my 1985 Corvette and it has worked great.
Old Jan 15, 2022 | 11:01 AM
ALG's Avatar
ALG
Thanks. This info I needed.
Old Jan 17, 2022 | 04:56 PM
ctmccloskey's Avatar
ctmccloskey
If you have a later model C4 Corvette that uses a MAF sensor and uses 2 external relays to control it like my 1988 C4 does be sure to replace the two relays when you replace the MAF sensor. Those relays are important and require replacement every couple decades.
The tubular connection between the MAF and the Throttle body needs to be well sealed and secured at both ends. You do not want any air leaks or your airflow measurements will be wacko and affect the drive-ability.
Old Jan 18, 2022 | 07:34 PM
Incorvettei's Avatar
Incorvettei
I was having issues with the MAF on my 86 so I took it off removed the screens on both sides and cleaned it with MAF cleaner. Problems solved
To 1986 Corvette MAF
