LS conversion Electronics
Old Jan 22, 2022 | 10:14 AM
haggar1850's Avatar
haggar1850
Originally Posted by STEVEN13
Edit-Just re-read your post #10 Looks like my questions are addressed.
I think a detailed thread would be helpful for 92-93 cars as they seem to be a challenge.
This is great information. Sounds like a nice combination. Systems like the heat, turn signals, defroster, fans, fuel pump, etc. Are they controlled with the stock ecm? What are you using for gauges? How did you address the CCM?
Hope the OP is okay with these questions I think it contributes to the thread.
Thank you,
Steve
The heat and defrost seem to work fine. I know there is a vacuum line that went under the dash, I didn't do anything with it. I use this one in warm weather only so I wasn't worried too much about the heat. I will tinker more with it this year to try to get AC running. Packaging the compressor is the only hard part there.
The fans are now wired to/controlled by the Nolley. Right now,, it's just the stock fans and each is controlled with a relay from the ecu. I will change this setup to a 3 relay configuration, that puts the fans in series for low,, and parallel for high.. I run this configuration in my GMC, it works well.
The fuel pump is controlled by the holley, and I replaced all of the fuel pump wiring to 10 gauge, run directly from the alternator stud.. the connector and bulkhead wiring are also beefed up and I run a 340 lph pump.
I run the stock 1992 instrument cluster. As I mention, all the gauges work fine. It's not too hard to run all of the stock C4 senders to feed the gauges, and all of the stock LS senders to feed the Holley.
I didnt really do anything with the CCM. I bypassed a vats relay to also the starter to crank. There is a SYS warning in my LCD, which I always had from changing the radio. (I never added a resistor). If I could get a accurate list of the CAN message set from the holley, I would make a custom LCD and replace the center. But the CCM still works fine. Power windows and locks all work normal
Old Jan 22, 2022 | 10:50 AM
STEVEN13's Avatar
STEVEN13
Thanks for posting this helpful information and videos of your car. Maybe one day I will attempt this.
Right now I am running the stock ECM with emulator. Forum member FrankieD is doing the tuning.
Thanks again!
Steve
Old Jan 22, 2022 | 11:05 AM
JoeNova's Avatar
JoeNova
Originally Posted by jdjenk
Megasquirt isn't too bad but its definitely not as easy as Holley. I had one in a 280z and my dad has one in his E type.
If I ever modify my 85 I'll probably just convert it to MS2/3 rather than try and tune the stock computer.
Avoid the older megasquirt stuff, especially from the self-assembly era. Very gimmicky, very hard to deal with.
Buy a completed setup from the higher end. Much less expensive than the Dominator with similar features, with a cost that comes in less than the Holley HP.
Old Jan 22, 2022 | 12:59 PM
jdjenk's Avatar
jdjenk
I self assembled the MS2 in my 280z, it wasn't a big deal.
There are definitely some things I'd do different the second time around though.
Old Jan 23, 2022 | 10:55 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Thank You for all the great information above I had little, or no doubt CF would come through with proven information. However just the Acronym's above are enough to drive me Nuts. I think my " Child Like" Batch Fired ECM with some tunning will the stock Gauges, ABS and TC all working will suit my needs quite well. Today I think I have scored a Lingenfelter Super Ram and if so, it will seal the deal on building an old school Gen II 383. Something I can do with my own Hands and Wrench's. .
