[scorp508 or whomever else has yanked the engine tips post]
Since I've owned this fine 383 engine, it has consumed a quart of oil every thousand miles. Under hard accel, it also blows a little oil out of the dipstick tube. The PCV system has been repeatedly checked and is ok(Last time I did a quick check with corvette0096 on the phone). Now, I am prepared for the worst as always,and my good friend and mechanic is going to do the re-ring and dis-assembly seeing I strongly feel it has blowby(Oil consumption is down to 800 miles to a quart).
Any particular tips or tricks to getting the engine out a little easier? My mechanic is just that, He works on Fords for a living so the task is safe at hand. He's just not LOYAL to the bow tie :D and doesn't know all the tricks(YET). This process will take place before the good weather gets here for sure. Hopefully everything looks good upon inspection. Valve seals are going to be done as well.
All this for a measly 39.000 miles use :D UN-REAL. (We will be doing a compression and leak down check first of course, but something tells me this course of action is needed)
Thanks in advance for any help.
Jay(Not yet insane)D!
Unbolt the accessories. You can leave the waterpump and balancer on.
Unbolt the headers from the engine and the y-pipe, and you can leave them just laying there.
Not sure how you want to deal with your tranny.
Take the plenum and the driver's side runners of to make it easier.
Put the chains to the corner bolts on the intake manifold.
Triple check all coolant, fuel, electrical lines are disconnected.
Get the chain slightly taught with the picker and then remove engine mount bolts.
Take your Super ram off before you pull the engine. Jd things have got to get better for you.. Oh one more thing.. Label wires and hoses. :thumbs:
[Modified by corvette0096, 1:47 PM 12/28/2002]
Make sure it is the engine and not something else.
Check for oil leaks and see if oil is getting ucked into the TB.
Also, some engine that run perfect do burn 1 quart every 1K - 2K miles.
A re-ring job is huge, the motor has to come out, then all the rods and pistons need to come out.
Vic
Sounds pretty straight forward. I'll certainly document the ordeal with photos of course.
Rich, I keep trying to tell myself the same thing. I've been through a lot. . . hopefully bad re-currances(sp?) will be non existant sometime in the near future.
good luck .
Really and truly hope yours is plug N' play!
Believe it or not,I thought the L98 engine removal was the easiest engine removal job Ive ever done.There really isnt much to it once the accesories are off.Just label the few vac lines and sensor/injector plugs and your set to go removing the usual bolts from the converter,engine mounts,bellhousing,etc.6 bellhousing bolts,3 converter bolts and 2 engine mount bolts and its about ready to come out(assuming you did removed the exhuast,hoses,drained the oil,coolant,etc etc etc).
Your mechanic will do just fine.
Also be sure to have the distributor out of the engine..that firewall is too close to take a chance.Pushing the tranny back helps and be sure to support it so it doesnt fall down with the motor coming out.
Have fun and keep us posted!
:D
matter of fact the bellhousing was still on there too...
in the future i would take the bellhousing off cuz it was kind of a tight fit, but there would have been tons of room without it on there.
i agree that my LT4 was the easiest motor i have ever pulled out.
even though i had to remove the exhaust and the transmission...
Hope it turns out, were you don't have to pull it :(
What did lingy say about it? I would think their work is good for more than 30k miles :eek:
As for pulling the engine it pretty straight forward. But before you pull that engine, I would do a leakdown test. It will tell you what cylinders are leaking if any. Don't use the compression test to identify the problem. When I did my compression test on my 350 (sveral times). It always returned results that were +/- 2psi. But the leakdown said differently. When I pulled the pistons out, EVERY top ring was broke in two. #7 was in about 15 pieces.
Good luck and I hope the leakdown said a different story.
Has performance dropped off any?
Perhaps he can step in and clarify if I am mistaken.
I knew he had knock too, and I agree with you that it will not take long to ruin rings and also put a hurting on the bearings. :nonod:
Scorp is right on. This engine had quite a bit of detonation. Again, it's a wonder I am still sane trying to correct this problem. It was partially solved by the trip to LPE. It still would not perform quietly(det free) with the timing at 6 deg.
In no way do I blame them. Sure, it's a little frustrating to even ponder the thought of yanking a 39,000 mile motor, but it is the truth, detonation is hard on parts. I think if this thing had anything BUT Forged internals, I'd have an overloaded ashtray by now.
The leakdown test is going to be the one, cause the car has ***** the size of Texas still :D so all is not bad.
Like I mentioned, I am ready for the worst. And to anyone reading this who is building or is even considering building a performance engine. Tuning is CRUCIAL to the lifespan of the engine. I'm again lucky it's still in one piece!
Thanks for chiming in with the help-ideas and feedback. I will definitely keep you all informed on the final outcome and plans.
Jay
[Modified by JD 90 383, 6:04 PM 12/29/2002]
