Dual In Tank Pump Install
Old May 26, 2022 | 12:49 PM
  #41
KSA Aaron's Avatar
KSA Aaron
Originally Posted by Racetronix
In-line / external pumps are totally different b/c they are not immersed in fuel and generally have poor suction capability so they are best gravity fed with large lines.
Regardless this application has nothing to do with our dual in-tank DIY kits and hangers.
What level of HP will the Racetronix dual pump kit support when feeding fuel through the OEM tank discharge line (<0.375"ID) as shown in the pic included above? I had asked the question prior, but it was never answered.
This was the reason I posted above, simply to make the point that the OEM discharge line is very restrictive feeding over the top.
Old May 26, 2022 | 12:59 PM
  #42
Racetronix's Avatar
Racetronix
Supporting Vendor
The answer to this question is very broad since many factors determine the fuel requirements for a given HP level such as fuel type, motor BSFC, operating temperature, supply voltage and target A/F.
Generally we state that staged twin 255LPH pumps can support apx 800FWHP FI on gasoline using the factory lines + rails with a base pressure of 43.5PSI @ 13.5V.
Twin 340LPH pumps can't be run on factory lines.
__________________
Manufacturer/distributor of Fuel System Components & Electronics
EST 1999
[b][url="http://racetronix.com/"]>WEB SITE
Old May 26, 2022 | 01:30 PM
  #43
KSA Aaron's Avatar
KSA Aaron
Are the pic I referenced with my first post above as well as the pic that Dizwiz posted shows both using the dual 340 pumps on factory discharge piping over the top of the tank? That was the point of my comment that the factory discharge tube in a C4 is simply to small (<0.375" ID) to support the HP levels that the dual 340 pumps are designed to support.
There was no negative meant towards the Racetronix pumps, moreover a comment that the factory lines need to be upgraded like the OP (and likely many others) have done.
This dual 340 pump is a nice fueling system for the higher HP C4s!
Old May 26, 2022 | 01:36 PM
  #44
Racetronix's Avatar
Racetronix
Supporting Vendor
The 3/8" fuel tubes on the hanger are not the issue. We can flow over 750LPH through the discharge port using our RXP340E pumps. The is the same as our DPFS-G7680EQ system. It is the fuel lines running through the car and the fuel rails that have the problem.
Old May 28, 2022 | 09:46 AM
  #45
dizwiz24's Avatar
dizwiz24
while my application isnt anywhere as powerful as Aarons, I upgraded my lines to -6 return , -8 feed, low restriction filter.
i used compression fittings on the ends of the 3/8” lines coming out of the tank. Put an adapter in them with -an nipples (-8 and -6 return) coming off of those.
i also hacked off the end of the 3/8” fuel tube inside the tank where it necks down to 1/4” .
so i hacked off the 1/4” portion of the metal tubing.
what i did NOT do was upgrade the fuel rail (1994-96 series style rail)
Instead, i put a fuel pressure gage sender at the end of it so I can monitor if it ‘drops’
no issues with e85, 80 lb/hr injectors, and prob 600-650 flywheel hp
Old May 29, 2022 | 04:15 PM
  #46
KSA Aaron's Avatar
KSA Aaron
Are there sections of the fuel lines that are reduced further than the discharge line over the top of the tank, or is it the continual 3/8" OD line all the way to the front of the C4? What specifically is the issue with the factory fuel lines that causes the issue for higher HP C4s?
