Cable release
Old Feb 5, 2022 | 06:23 PM
johnfin's Avatar
johnfin
Default Cable release
Any of you guys have the plastic end break off. I guess the only way to fix is a replacement. Also how do the emergency cables attach?
Old Feb 5, 2022 | 09:18 PM
s carter's Avatar
s carter
When the hood cable is properly in and adjusted the tip you're missing is just a retainer to hold cable in spot, if you wish you can probably put some Epoxy in it's place.
. The outside backup cable which I think is a good thing to have, I used a Heavy Duty Deep Sea stainless fishing leader that had the Lure End and I just hooked around the latch arm with cable run to wiper arm valley.
. With the set up you have you need to remove the hood cable from its clip and then loop the arm and then reconnect the factory cable. Be careful with that clip finding it might be hard to find.
Old Feb 6, 2022 | 08:44 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
I would recommend fixing it right the first time and replace the cable instead of trying to cobble up some type of "fix".
Your aux. release cable looks pretty heavy duty. I made my own cables, and this is how I attached them:
And here is the routing:
Old Feb 6, 2022 | 10:07 AM
LT-1 kid's Avatar
LT-1 kid
do you need the aux cable on both releases
Old Feb 6, 2022 | 11:55 AM
s carter's Avatar
s carter
. Yes if you look at Red86Z51s photos he is showing the Passenger side the system uses 2 independent cables coming from 1 pull lever, and even if only 1 side fails access to the other is a pain. So installing a little cheap secret by wipers could save a lot of angry words and thoughts about the Design & Designer's
Red86Z51's Avatar
Red86Z51
Yes, only for the simple fact that either side can fail, and you won't know which side will go...until it does. Although there can be different reasons for a latch release failure, my experience has been the retaining clips that attach the cable to the latch mechanism snapped.
Old Feb 6, 2022 | 12:37 PM
johnfin's Avatar
johnfin
Awesome pics, thanks for posting.
Old Feb 6, 2022 | 12:54 PM
Red86Z51's Avatar
Red86Z51
Old Feb 6, 2022 | 02:14 PM
Whaleman's Avatar
Whaleman
I would suggest putting a smear of heavy grease where the hood pin hits where you show some rust. Dan
To Cable release
