Recipe for 350HP
Old Feb 6, 2022 | 08:43 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Default Recipe for 350HP
Need a Parts shopping list for a 1991 L98 A4 to get her up to 350HP (No blower or juice), appreciate if someone already went to that to share the details.
already have the following:
- Borla S-Type Cat back
- Hooker 2149
Appreciate the feedback and details with parts brands & no.
TIA
Old Feb 6, 2022 | 08:45 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Cam ported
Ported heads or heads
Intake
Tune
Old Feb 6, 2022 | 08:51 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Originally Posted by Tom400CFI
Cam ported
Intake
Tune
no porting, going for new parts.
which brands or part no's if possible will be appreciated.
thx
Old Feb 6, 2022 | 08:53 AM
Incorvettei's Avatar
Incorvettei
AFR195 heads would be a good start, ZZ4 camshaft and long tube headers as well as a good tune will get you to 350hp
Old Feb 6, 2022 | 09:00 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Thx, the LTH already i have (Hookers)
what about intake? FIRST seems good?
Old Feb 6, 2022 | 09:53 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Any not-stock TPI intake will get you there with the other mods suggested. So, I'd start looking in the classifieds, ebay etc for and "big tube" TPI, HSR modded to fit a C4, Super Ram, Mini Ram, or any other "TPI" replacement intake that is either bigger runner and/or shorter runner. The IDEAL intakes for a street motor that is stock displacement (like you're proposing) is a Super Ram (harder to find) or a T-Ram (very hard to find).
Old Feb 6, 2022 | 10:35 AM
Kevova's Avatar
Kevova
Budget? Idk under your parameters shopping for a crate engine with the chip or prom to make it work could be more cost effective. The problem is 350hp will lead to 400 and so on. Not on the LS band wagon but it is a viable option
Old Feb 6, 2022 | 10:48 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Who sells an L98 create engine with a chip? : I wasn't aware that that was a thing?
Old Feb 6, 2022 | 11:06 AM
Kevova's Avatar
Kevova
This engine still just a sbc. Several different intakes available. tuners should have notes on previous tunes and builds. This isn't rocket science it just about money. I'm certain several members who are regulars on this board could supply an engine with the tune to make it work.
Old Feb 6, 2022 | 11:07 AM
yakmastermax's Avatar
yakmastermax
Would be very interested to see what you get with the FIRST TPI. You're keeping the displacement at 350 cu in?
I would be interested to see long tube headers, true dual exhaust, either high flow cats and or mufflers or maybe delete cats and mufflers entirely.
Perhaps upgraded fuel pump, fuel pressure regulator (I think this might be a necessary part of installing the FIRST TPI), and maybe upgraded injectors?
Then a well chosen cam, and a good tune. I am curious if you can get to your 350 rwhp without changing the cylinder heads.
Old Feb 6, 2022 | 11:11 AM
JackDidley's Avatar
JackDidley
Put a Miniram on top and you will be there. Will be a fun car.
Old Feb 6, 2022 | 11:26 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Thanks for the inputs..
Crate is not possible, keeping it 350 (for now). have to go with what I have, I'm not looking to compete just fun to drive car with fun passes on the road.
so, ingredients:
- Borla Cut Back system (Available - not installed yet).
- Hookers 2149 (Available - not installed yet)
- FIRST Intake (complete with rails, TB, Fuel reg...etc)
- ZZ4 Cam
- AFR 195 (is it really needed if a keep it 350?) or the stock will do just fine?
- 1.6 RR (brand??, self aligning or not??)
- Tune
anything else?
Old Feb 6, 2022 | 11:48 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
AFR heads will com with guide plates, so NON self aligning rockers, if you decide to add rockers.
I'm sure. Those aren't crate motors though. Those would be "member built and tuned, custom motor". Your post above was misleading....to me at least, it sounded like you could order up a crate motor from Summit or Jegs and it would come with a Chip....which of course, you can not do.
Why are you advising the OP to spend money on this?? I already told you in your thread, that you don't need to be doing "fuel system upgrades" for 350 horse. OP; don't be throwing pumps, regulators and injectors at your combo unless it's shown that it needs it.
Old Feb 6, 2022 | 11:59 AM
yakmastermax
I said perhaps and maybe...
Old Feb 7, 2022 | 10:37 AM
JoeNova's Avatar
JoeNova
How mild do you need it to idle?
The ZZ4 cam is OK, but there are absolutely better camshafts out there for less money.
Old Feb 7, 2022 | 10:50 AM
vader86's Avatar
vader86
You have to decide the intake to get there. I could come up with a head/cam choice for any intake, but they wouldn't be the same. Hence, make a choice. SR, MR, HSR, FIRST, etc. Really depends on where you want the powerband to be.
The difference in power from the 91 to 92 is really the intake, so slap a MR on a 91, and you basically have the LT1's powerband, and about 290-300bhp. You only need 50 more, and thats the cam and head choice.
I would be going with more than a ZZ4 camshaft, particularly if going with the Miniram. At a minimum a TPiS ZZ9 if that were the case.
AFR 195s would be overkill to get to 350hp on a 350sbc. Could have the current heads ported and get that number, and end up cheaper. I imagine getting that done in Dubai would be the problem though. I would go with something cheaper or a little smaller than 195s if 350hp is the only firm goal.
In any case, upgrading the TC from the stock wimpy 1500rpm stall to 2000-2200 is a necessity.
Old Feb 7, 2022 | 10:58 AM
JoeNova's Avatar
JoeNova
If you're going with a good aftermarket intake and going as far as AFR 195s to match, I'd skip the small ZZ4 and go with something like the Summit Pro SBC Stage 3 camshaft.
Converter to match, without a doubt.
To Recipe for 350HP
Old Feb 7, 2022 | 11:09 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I've seen this written on forums many-a-time. And for the most part, I've believed it, but at this point, I'm going to say, "No way".
My '92 did 279 RWHP with a K&N air filter, for it's "mods".
My '89 did 258 RWHP with a Mini Ram intake, 52mm TB, no air filter, advanced timing, dual exhaust, H-Pipe w/no cats, 160 stat, no smog pump/AC, Underdrive pullies.
So, no, an L98 w/a MiniRam is not an LT1. Not even close, really.
Old Feb 7, 2022 | 11:10 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Thx guys for the feedback.
I'm leaning towards the FIRST to keep the stock look.
so which combination would be best for it?
The 350WHP is the minimum for now, might go up later
Old Feb 7, 2022 | 11:12 AM
JoeNova's Avatar
JoeNova
350 HP and 350 at the wheels are 2 very different goals. You're going to want to forego purposely giving up power in hopes of keeping up a stock look if you want that 350 to be at the wheels.
