power brake booster leak
Old Mar 3, 2022 | 06:30 PM
Casethecorvetteman's Avatar
Casethecorvetteman
Originally Posted by krackenvette
Learned allot. Thnx.
Ona side note, are these sensitive to low vacuum from the engine?
Not really, they're reasonably fine unless vac becomes too close to atmospheric pressure.
Old Mar 3, 2022 | 08:42 PM
krackenvette's Avatar
krackenvette
My vacuum is around 14 out of gear.. In a little lower..
Old Mar 4, 2022 | 12:49 AM
Casethecorvetteman
Should be fine
Old Mar 4, 2022 | 10:01 AM
krackenvette
Its a little hard, but I am used to it. Been like that for about 10 years. New booster OEM booster sitting on shelf if I need one.
Old Mar 4, 2022 | 03:37 PM
Casethecorvetteman
Yeah it is meant to be that way, that isn't the booster, that is a combination of pivot point and master cylinder bore size.
You want the pedal firmer so it takes effort to push, you have better feel and better control.
