power brake booster leak
1. I can feel the shaft that is depressed via the brake pedal and it does have what appears to be some rubber gunk/rust on it based on what my fingers look like after grabbing it.. Since this appears to be a pretty major job to replace, I figure I have two choices besides that. Keep driving it and hope it goes away.. or maybe try rubbing some rubber seal expander on the shaft and getting down on my knees for bit and ask for forgiveness. Was looking at reviews on this:
2. I havent popped open my factory manual but it looks to me like the entire brake master cylinder has to be removed.. and also will need to break my back and neck climbing into the drivers area and removing nuts etc... Am I right as to how horrific this job is going to be?
Opinions? Thoughts?
I could also bleed my brakes which would allow the rod to go very deep.. However, could trash my master cylinder. Big mistake some make, bleeding brakes on an old master.
1. I can feel the shaft that is depressed via the brake pedal and it does have what appears to be some rubber gunk/rust on it based on what my fingers look like after grabbing it.. Since this appears to be a pretty major job to replace, I figure I have two choices besides that. Keep driving it and hope it goes away.. or maybe try rubbing some rubber seal expander on the shaft and getting down on my knees for bit and ask for forgiveness. Was looking at reviews on this: https://www.amazon.com/Hapco-Product...1M1A0O61&psc=1
Opinions? Thoughts?
On the 90, we were able to remove the master cylinder WITHOUT disconnecting the brake lines from it. There was enough room to push it aside and wrangle the old booster out. We did have to remove the ECM bracket and set the ECM out of the way, but didn't have to pull any of the connectors out. Total time for removing the old and installing the new was probably around 3 hours (and I'm a pretty cautious, methodical guy). Unless the 96 is dramatically different, I wouldn't be too scared of this job.
Opinions? Thoughts?
To confirm what you are saying, there is no leak until you push on the brake pedal?
When you push on the brake pedal it is quite firm like there is little or no vac assist?
When you start the car, holding foot firm on brake pedal, does the pedal become easier to push down the instant the engine starts or stay firm?
Removal is not outrageously difficult, two nuts inside under the dash, two nuts on the master cylinder, and you will need to move the PCM being a 96 as well. easier job on an 84-89, i just did one a couple weeks ago.
I used to rebuild those PBR boosters here in Australia, they are used on a fair few different models of Australian cars. Unfortunately i am no longer able to get the rebuild kits from PBR anymore, only replacement complete assembly.
This will show you some of the internals, however i do not recomend you open the booster yourself unless you have the correct tool to re-assemble and very strongly suggest you read the section about brake booster rebuilding in the factory service manual first. There is a big spring in there under constant load, so be very careful.
https://www.youtube.com/watch?v=FUdPJhLV7bI&t=28s
When you push on the brake pedal it is quite firm like there is little or no vac assist? NO
When you start the car, holding foot firm on brake pedal, does the pedal become easier to push down the instant the engine starts or stay firm? EASIER
Either way, that booster is likely buggered, and very close to total failure. You can see the size of the split in my video, that is total failure. A split that is 1/10th of that size will still hiss, but the booster will still function, albeit with limited capacity.
If you hear a hissing noise inside the car constantly when you have your foot on the brake, the diaphragm is rooted. It is normal to hear a hiss as you push down, but it should be very brief.
There is no seal on the rear of the booster. The way it works is the reaction disc inside the rear half of the unit stays against the air inlet and thus holds the front and rear halves of the booster at manifold vacuum. When you press on the pedal, the pushrod moves the reaction disc forwards, which then does two things, it opens the rear half of the booster to atmospheric pressure, and seals the front half so it stays at manifold vacuum, causing the diaphragm to pull the piston to the front of the booster.
When the diaphragm has a split, the reaction disc is still pushed forwards and seals the front half via the center air passage, but at the same time the diaphragm allows atmospheric pressure to be drawn through the booster from inside the car and into the engine.
There is no "poppet valve", there is a reaction disc, and i describe above how that functions.
You reaching in with your hand is not going to come anywhere close to the reaction disc. In your first post you say there is a leak when you push the pedal. Clearly, the reaction disc is NOT leaking, it is doing it's job correctly.
In well over 2 decades of rebuilding these boosters i have never once seen a reaction disc fail. They came in the rebuild kits, but i rarely bothered to replace them. Often it was hard to tell which was the used one.
As you will clearly see, there is no hope you will reach the reaction disc from inside the vehicle, or from outside the booster for that matter. It is deep in the middle of the booster, and there is almost 0% chance this is your problem, and i say this because there is no vacuum in the rear half of a correctly functioning booster when the brake is applied. The reaction disc is obviously doing it's job, or it would hiss constantly and stop hissing when you push the pedal, you report the opposite.
This is the pushrod coming out of the vacuum piston
These are the components when removed from the vacuum piston, left is forward pushrod, right is rear pushrod assembly, and middle is the reaction disc.
This is where the reaction disc goes inside the piston.
Originally Posted by barchetta1 View Post
To confirm what you are saying, there is no leak until you push on the brake pedal? YES
No vac assist or no to that comment?
You're an expert but you had to ask us mere mortals here, and you seem to want to argue with the diagnostics information given by someone that has more than 20 years experience in rebuilding the very same booster you are asking about.
You start out by trying to suggest there is a way to seal the rear of the booster from inside the dash, even though you have said it is leaking when the pedal is pressed. Clearly, and of course you would know this because you know all about these boosters, there is NO VACUUM IN THE REAR HALF OF THE BOOSTER WHEN IT IS FUNCTIONING CORRECTLY, SO WHY WOULD YOU WANT TO SEAL THE BOOSTER FROM INSIDE THE CAR??? Even in the booster you show, which isn't the same, if that valve was leaking it would have a vacuum leak with FOOT OFF the brake pedal, not foot on. Only one way that vacuum can draw on the rear half of the booster when the pedal is pressed, and that is a failed diaphragm. But you knew that already
To top it off, you come along and show a diagram of a booster made by a different manufacturer, which is a slightly different design, and has different components, to achieve the same end goal. In that diagram you show, the valve you speak of is OPEN TO ATMOSPHERE when you push on the pedal making your theory of a leaking valve completely incorrect, but you'd have known that too.
Not going over it again. If you want to challenge what is said and suggest my diagnosis is wrong, have fun mate
