ECM getting hot with ignition off..
With ig off I have disconnected both ECM plugs and have 12 volts on two terminals that I don't understand.
C1, green/white, Fan Relay Control, and D12, black, Burn Off Relay Control.
I have swapped out both relays but have same result.
When I start the engine it fires right up and runs well. The thermo fan cuts in/out as it should and I have no codes.
I keep disconnecting the battery in case the heat will do harm to the ECM.
Can someone please shed some light on this?
I have searched the net and can't find the answer...
