Need a very serious radiator!
Old Mar 27, 2022 | 04:25 PM
vetterobert's Avatar
vetterobert
Default Need a very serious radiator!
Hi guys,
1987 C4 Corvette, standard trans.
600 plus horse Big Block!
Mojave Desert --> 130 degrees in the shade!
A/C obviously a must.
Want engine temps well under 200.
Please guys, no lectures on airflow, fans, etc. I get it, I really do.
Unfortunately, I really am on a tight budget. I don't think a "drop in" instant fit radiator will work, and a universal type radiator should be cheaper--> I'm prepared to do work both to save money, and to get very best cooling.
To show my dedication to getting this to run cool though, I am considering ripping everything out to make the "gills" airflow functiinal, and maybe even installing auxiliary mini-radiators there.
I don't mind fabrication or modification.
Thanks!
Vettepilot
Old Mar 27, 2022 | 04:32 PM
don hall's Avatar
don hall
Just 1 humble suggestion:
https://www.motortrend.com/how-to/cc...ooling-system/
Old Mar 27, 2022 | 04:33 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I think Aux radiators in a C4 is a good idea. IDK that the "gills" will flow enough, unless you cut more slits into them?
I've always thought that the spare tire carrier would be a great location for an 2nd radiator. Ditch that thing, mount a large radiator horizontally in the rear and I'd think that the air flow over it, at speed would add a significant amount of heat rejection. Added capacity for that part of the loop would help slow temp rise at stop/idle even w/o a fan on it.
Old Mar 27, 2022 | 04:45 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by don hall
Well THAT article is junk; it talks about speeding up water flow....for better cooling!? I mean, COME ON! We ALL know that you gotta restrict water flow to improve cooling! get w/the program, dude!!
I'm kidding, of course.
Old Mar 27, 2022 | 04:59 PM
WVZR-1's Avatar
WVZR-1
What 'accessory drive' w/AC are you using or there ain't one yet? What is the 'Big Block'? Is it actually installed? They ain't all the same either!
Old Mar 28, 2022 | 03:18 PM
Bill Chase's Avatar
Bill Chase
Dewitts, be ready to drop some coin, they can custom make you a rad that will fit in the stock location and be a 3 pass etc. Until you get over 400 rwhp the stock radiator is actually pretty good.
Old Mar 28, 2022 | 03:58 PM
rklessdriver's Avatar
rklessdriver
KKS 3 row radiator off Ebay. $215.00
I ran one in my 785hp 84 drag car for years. Biggest problem I had was keeping any temp in the engine. I even used it's internal cooler for my TH350 and later Powerglide with 4500 and 6000 stall converters. I drove the car on the street often and it always ran cool (under 180F). Of course electric water pump and no thermostat. Excellent radiator for the cost.
Will
Old Mar 28, 2022 | 04:59 PM
vetterobert
Thanks guys. I read all references and links. Keep 'em coming. Actual experience reports are great.
Engine is an honest 550 horse 454, already built and waiting for install. I'm presently working on various upgrades on the car, such as the radiator situation, in anticipation of being ready to throw the big block in. I haven't decided whether to use the old V belt drive setup, modified as necessary, or to adapt the small block serpentine drive to the big block. I've read articles on that and it's not too tough, but finding an aluminum, high flow, short water pump in reverse rotation for the BBC might be a challenge.
Vettepilot
Old Mar 29, 2022 | 09:52 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Will
Thanks for posting this. Wish I'd know about it when I bought a new radiator.
Old Mar 30, 2022 | 04:55 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Will
What fan did you run with that? FWIW, I tried a 160-stat for a bit and think it stuck open. In the winter, it wouldn't get above 130 on the hwy. Without A/C, it would take quite a bit to "heat up" and really only when I was running A/C. So, the fan might be good to know...as well as the length of "street runs". Gotta assume no A/C on a drag car.
Got any idea what brand KKS is? Do they sell other "good" stuff?
Old Mar 30, 2022 | 08:17 AM
Phobos84's Avatar
Phobos84
The Griffin Racing 1-25241-X fits the early C4's without too much issue. You need to trim the upper and lower shroud a little. I made new rubber feet for mine to set in. I don't have AC in my car. But I think it should fit fine with AC being that your car is a standard so you don't also need a trans cooler like I do. But the Griffin radiator is made in the USA and is only $200 shipped. Also the thing is 3" thick so cooling is very good. I run mine with the factory fan with no issues.
Also my Vette is a street car. It does very well for me with a built motor in traffic.
Old Mar 30, 2022 | 11:32 AM
cv67's Avatar
cv67
St. Jude Donor '05
go overkill on your fans...OEM fans kick **** and last forever. Luxury car, truck, etc.
I never see heat management mentioned.
-Adapting a ZR-1? Fan shroud to a C4 with the hole in the hood? No clue if it would fit.
Open up those gills
Let some pressure out from under the hood..maybe get creative with some 'glass vents of some type.
Integrate an isolate cold air deal for your engine at the same time
Not those cheesy black plastic stick on deals you see. That could be fun. Had a few big blocks, they are one giant heat sink
but SO worth it..that torque is addicting. I have a SBC at roughly that power level, different car with better airflow than a C4
with one of those 16" spals...not adequate. There are brushless "smart" fans out those are super efficenet, nice. You could have some fun with this project.
Post up when youre done. Im in so Cal too...how in the hell are you gonna smog it? Please share. Im in Hemet gets fn hot out here not like Mojave though.
Edit Noticed MB uses an almost false 2nd firewall that isolates the braking system and more from heat. Another option to think about.
Old Mar 31, 2022 | 09:04 PM
rklessdriver
Stock fan. Worked great on my 16v system... so, so when I still used the 12v. When I still street drove it, I kept things easy, like to car meets on weekends 10-15 miles one way at most but I was range limited by the 5gallon fuel cell. Traffic here near DC can be brutal and best to be safe with street driving something like my 84.
Far as I know KKS Motorsports is the brand. I don't know what else they sell. It was the only inexpensive big direct fit C4 radiator that has stamp formed end tanks... honestly that was the reason I chose it over a Champion or other imported radiator with welded flat sheetmetal tanks. I had used a Champion in my wife's 79 C3 and while it cooled well it didn't fit the factory brackets worth crap.
If you look at my other posts, I just converted the 84 to a lightweight G Plus brand Civic radiator. I put the KKS C4 radiator up in the rafters of the shop just in case I ever decide to put the 84 back on the street.
Will
To Need a very serious radiator!
