Running issue
Old Apr 4, 2022 | 06:24 PM
Jez28's Avatar
Jez28
6th Gear
Default Running issue
Hi all,
I have been having some rough idle and running issue so I was checking my timing, I unplugged the cable by the bulkhead to do the timing check. This smoothed everything out. The car ran fine.
89 TPI.
Any ideas on why would this happen?
Old Apr 5, 2022 | 02:11 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
year?
Old Apr 5, 2022 | 03:57 AM
Jez28's Avatar
Jez28
6th Gear
That would help. 😁
89 TPI.
Thanks.
Old Apr 5, 2022 | 09:28 AM
VikingTrad3r
Oil Producer
i believe i would start with icm. ignition control module. another possibility being pickup coil down in the shafr of the distributor.
a new distributor would be pricey but would be complete i think
even a used corvette hei would be good
see what others say too
Old Apr 5, 2022 | 12:06 PM
jazfe's Avatar
jazfe
When you unplug the bypass you disconnect the ICM
That should be your issue.
To Running issue
