Engine code being generated, but scanner shows "No Data"
Old Dec 31, 2002 | 12:35 PM
jimijoe's Avatar
jimijoe
Default Engine code being generated, but scanner shows "No Data"
My 94 sputters ( well more like cuts out) under light to moderate acceleration. The "service soon" is on (I believe this means its generating a code), but when I took it to my mechanic to dianose, the scanner showed "No Data". We checked the fuses to the EMC, all good.
Any Ideas?? :confused:
Old Dec 31, 2002 | 12:44 PM
VetBoy89's Avatar
VetBoy89
Default Re: Engine code being generated, but scanner shows "No Data" (jimijoe)
ECM RESET: GM VEHICLES
By Roy, BAT Auto Technical
An ECM (computer) reset occurs when either circuit power, circuit ground or reference signals to the computer are lost or overloaded
If the vehicle is having intermittent driveability problems such as surging, bucking and/or stalling and the CEL (check engine lamp) is seen either solid or flashing with no trouble codes being stored then, there is a good chance that a reset is occurring. This can sometimes be seen with a scan tool as “NO DATA” or, the scanner seems to “freeze up” while the reset is occurring.
Any time you have an intermittent driveability problem with no CEL or stored trouble codes the power, ground and reference circuits should be checked by making sure all connections are clean and secure. The ECM can’t store codes if it doesn’t have power or ground circuits. I’ve found that the ground circuit that is at the thermostat housing on some GM vehicles is a potential ECM ground problem so, I add a ground wire from the battery negative post to the ground at the thermostat housing. I’ve also found ground circuits that were attached to a head bolt, and the bolt was broken. So if you have a ground circuit at a head bolt be sure and check the bolt.
Another type of reset is an internal ECM circuit failure. These usually occur after the vehicle has been driven for a period of time and are affected by temperature and vibration. To check for this condition, remove the ECM from it’s mounting but do not disconnect it from the vehicle harness. Place it as close to the heater outlet as possible and set the heater to full heat and highest fan speed. After the ECM becomes warm tap firmly with the tips of your fingers on the case of the ECM. Nothing else, just your fingers! If the engine sputters or dies or the CEL comes on or flashes while your doing this “tap test” the problem lies within the internal circuits of the ECM. This will require an ECM replacement.
Mine stopped storing codes right before the ECM went crazy on me. :seeya
Old Dec 31, 2002 | 01:02 PM
jimijoe's Avatar
jimijoe
Default Re: Engine code being generated, but scanner shows "No Data" (VetBoy89)
Thank you for your quick reply. My problem sounds like the ECM one you described. The problem is definatly heat related. The car runs fine when its cold, but as it warms up it runs worse. The mechanic suggested me that maybe the dealer has a process to test it.
To Engine code being generated, but scanner shows "No Data"
