TV Cable Delete?????
Old Apr 11, 2022 | 12:09 AM
TheKodiak's Avatar
TheKodiak
Default TV Cable Delete?????
I got my hands on a 1996 slightly modded vette, with only 40K miles. The guy said it would shift, but you had to release the throttle to get it to shift. When I drove it, it seemed that way, but it also seemed to stay in first. When still and shifting into all gears, there's no jerk or clank of any kind. When I looked under the hood. I noticed that the Throttle Valve Cable isn't there. He said something about having it tuned and items deleted. Which goes back to the title. Can a TV cable be deleted? I got it great deal on it, and I don't mind dropping some coin on a new tranny. But Thank you in advance!
Old Apr 11, 2022 | 01:13 AM
Krusty84's Avatar
Krusty84
I am fairly certain that E transmissions don't have TV cables.
Old Apr 11, 2022 | 08:46 AM
WVZR-1's Avatar
WVZR-1
It never had one - a '94+ 4L60e is electrically controlled. The first stop for you should be to a shop that will actually do a 'diagnostic' check. Many do that 'no charge'. The PO mentioned 'tuned' - well .... the sooner you do the drive to a shop for 'diagnostic' check the easier it could be on the wallet. You'll soon know how GOOD the deal actually was.
Old May 20, 2022 | 08:47 PM
TheKodiak's Avatar
TheKodiak
You guys are absolutely right. There is no TV cable. I also noticed there's no governor. It's going to cost to do a diagnostic here at GM. He said around $143. I already swapped the entire 2-4 band assembly. And the fluid twice. It was very dirty with very little dust like fine shavings
To TV Cable Delete?????
