Knock sensor comes in contact with red line Has anyone had this issue before? I would prefer to avoid modifying the headers, but does anyone know of a possible solution for this? The passenger side knock sensor goes in no problem since its at a different position on the block.
So I have had the ARH headers on my 96 LT4 for several years and did not have this issue. But I have two knock sensors on my engine that look like they are in a different location than yours. On mine there are metal heat shields over each knock sensor connector, they came stock from the factory to protect the wiring/connector. I have enough clearance between the header tubes and the shields.
I did have trouble with the catalytic converter placement being too close to the floor. I could just about get a finger width between the floor and the cats.
I made a metal shield over each cat and also used Thermotec heat barrier and stuck it to the floor by the tunnel.
There any reason why mine is not in this location? I'm really confused as where to go from here regarding this...
I'm not sure where it is bolted up to, but plug the hole with a 3/8" pipe plug and relocate the knock sensor to the bottom of the block. I have been running ARH stepped headers for years with no knock sensor clearance issues but I do not have a Lt1 block.
It would be interesting to know where the KS is mounted, the OP's snapshot was a bit vague. The test will be what he actually needs, the KS I believe is 1/4 NPT and I actually believe that some have purchased blocks that had 3/8 NPT female threads at the oil pan rail and they needed a bushing. The shields left side are same '92+ so I assumed the KS location the same.
This fellow had the 3/8NPT issue on an engine he had bought:
The passenger side/right side of the block has the location similar to what WVZR-1 said, but it isn't the same on the other side. I can check to see if there is another hole lower down on the side of the block but that wouldn't make much sense since there is also this hole. Sorry not the most experienced when it comes to this stuff, first time pulling rebuilding and remounting the engine so I'm a bit new to all of this. Thanks for all the help and suggestions, I will keep you guys posted!
I've had browser issues lately where it seems that recent posts to a thread don't appear sometimes for hours. This one the OP seems to have likely responded @ 12:17 EDT but here for me @ 2:56 it hasn't populated. An AD blocker issue?
****Posting this response seems to have 'forced' the 12:17 post.
OP check your block for a threaded port in the vicinity mentioned, did your right side have a shield that attached with 2 of the pan bolts? Those 2 pan bolts might have been studs.
I'm surprised that someone with a '94 hasn't posted.
There actually is such a thing as a KS relocator. Ron Francis and others offer it. A few years ago it was mentioned in a C4 post.
