'94 SES H64 code at idle
Old Apr 15, 2022 | 08:01 PM
mattski11's Avatar
mattski11
Default '94 SES H64 code at idle
Got the car back on the road today after replacing the head gaskets. The car is running great. After the first drive I let it run while I got out and checked for leaks. Heard the engine sputter a bit then saw the SES light. H64 right bank O2 sensor lean is what I'm showing. I went for a second drive, ran great again no SES light. Let it run for a bit and threw the code again. Seems to be throwing the code as the engine heats up after sitting for a bit. Any ideas what could be causing it?
Old Apr 18, 2022 | 09:59 PM
belairbrian's Avatar
belairbrian
Sounds like the car is getting warm enough to enter closed loop operation. At that point the O2 sensor inputs are being used.
