I am having a heck of a time removing the pilot bushing on a 350 chevy. I have a decent slide puller for the job but it wont come out. I heated it with a torch and even put slits in it with a micro saw to loosen the force but it wont budge. Any thoughts?
I haven't done many pilot bushings, but I just used a hammer and narrow chisel to break it into pieces. Cutting slots into it makes that much easier.
I've also heard of filling the cavity with grease and slamming a pilot shaft into it. The hydraulic pressure on the grease is supposed to push it out. I've never tried that.
I used a wet paper towel , a bolt and a hammer. The bolt doesn't have to fit tight. The bushing popped right out. This is safer and not as messy as grease.
So I got the bushing out with brute force but.....when I installed the clutch I remembered that I was suppose to ( or at least I think I should) put thread locker on the bolts to
the flywheel to the crank. I torqued them to 80ft lbs. I know the newer cars use thread locker on the bolts and you can see traces of it on the bolts but I didnt see anything on
these 40 year old bolts. Engine only has 180hp I think so I am not sure its necessary. What to you guys think?
I actually had a pilot puller on the work bench... worked great. I've also seen, Grease, Bread, Irish Spring, and I think Vaseline used as well... I don't waste bread... Italian family lol...
