tricks to remove pilot bushing?
Old Mar 11, 2016 | 10:02 PM
Nater70vette's Avatar
Nater70vette
Cruising
Default tricks to remove pilot bushing?
Replacing clutch in my 70' 454. Any tricks to get pilot bushing off?
Old Mar 11, 2016 | 10:10 PM
jkippin's Avatar
jkippin
try packing it with grease and driving a drift into the center. The grease should build up enough pressure to hydraulically remove it.
Old Mar 11, 2016 | 10:11 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Get a piece of rod that's a nice fit inside the bushing. Pump the hole full of grease and then tap the rod in. The grease will push the pilot bush out. Haven't done a bbc, but I've not struck an engine this method didn't work for me on.
Edit: jkippin beat me to it!
Old Mar 11, 2016 | 11:23 PM
Nater70vette
Cruising
Thanks guys. I'll do that.
Old Mar 12, 2016 | 01:06 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Like metal head said rod has to be snug fit to pilot bush .I used modelling clay instead of grease on my 427 .
Old Mar 12, 2016 | 01:15 AM
20mercury's Avatar
20mercury
Default another option for you too.
Another option too for you that I got from this forum.
Assume you have a bronze pilot bearing and not a roller bearing pilot bearing
1. Get a 5/8" or 3/4" bolt, about 2" long, you want the od of the threads to be slightly larger than the id of the pilot bearing.
2. Grind or file the end of the bolt threads to a taper so that about 1/4" of the bolt will go in the pilot bearing id. So, now your threads resemble tapered pipe threads.
3. Screw the bolt into the id of the pilot bearing and when it bottoms out, keeping screwing and the pilot bearing will come right out.
I have used this method 3 or 4 times and it works great.
Hope this might help.
Old Mar 12, 2016 | 02:44 AM
Majoho's Avatar
Majoho
This is a good method but BE SURE to wear eye and face protection before doing this. The grease can squirt out of there at EXTREMELY high speed and do potentially severe damage to your eyes. I've seen this happen, and it was not a good thing.
Old Mar 12, 2016 | 02:58 AM
Solid LT1's Avatar
Solid LT1
Buy a 5/8 coarse bolt, taper the end with a grinder, cut a notch into the threads perpendicular to the threads (like a thread tap with only one relief) bang it into the pilot bushing and screw the bushing out....this method has worked for me since 1975....
BEFORE you install the new pilot bushing, find a magnet and see if the new one is magnetic, if it is.....THROW IT INTO THE TRASH! where it belongs and either order a proper "Oilite Bronze" bushing from Auto Gear Transmission or try to find a proper one at an auto parts store (bring a magnet along on that trip.) The magnetic bushing will squeal like a pig if you use it....(thank you China for all your quality parts!)
Old Mar 12, 2016 | 12:03 PM
bj1k's Avatar
bj1k
Recently there seems to be a lot of cheap bronze pilot bushings out there . I asked for a good quality bushing at Advance but made the mistake of not sliding it on the pilot shaft to check it before installing it. I slid it on the installation tool and it seemed fine but the tool is slightly smaller than the input shaft. The inside tolerances were so tight that it wouldn't let the pilot shaft spin free and I couldn't get it into gear with the engine running. Had to pull it again and install a NAPA pilot ball bearing and all is fine .
Old Mar 12, 2016 | 12:39 PM
Richard454's Avatar
Richard454
Or go to you local chain autoparts store and they have a Tool loaner program. And not just pilot bearing removers- but a whole host of specialized tools.
Put a deposit ( usually the cost of the tool) on your card- have 90 days to use it- No cost at all!!!
Advance Auto is few miles from my house- so I've used them-
http://shop.advanceautoparts.com/o/loaner-tools
Old Mar 12, 2016 | 03:13 PM
ImFixingHerCar's Avatar
ImFixingHerCar
I used a slice of bread when i did the pilot bearing on the M3 engine swap in my 3 series. Cheap, worked great, and less messy than grease! I was fortunate to have a bolt nearby with an inside diameter that was slightly smaller than the bearing. Just gotta keep packing and whacking until the sucker pops out!
Old Mar 13, 2016 | 08:52 AM
croaker's Avatar
croaker
I've used both methods once I tried the bolt I'm sold
Old Mar 13, 2016 | 08:56 AM
croaker's Avatar
croaker
My Napa store said mine called for the roller type. They are only as good as their puter
Old Mar 13, 2016 | 01:06 PM
bj1k's Avatar
bj1k
Sorry for the typo , meant to say needle.
Old Mar 13, 2016 | 01:16 PM
croaker's Avatar
croaker
Sorry I meant they are only as good as their computer
To tricks to remove pilot bushing?
