overheating
I would also do a coolant system pressure check. You can probably borrow one of these testers from an auto parts store. If those both pass, then I would wonder how efficient the radiator was. It could be clogged.
What needs to happen next in this thread, is that the OP needs to answer some of the questions that have been asked. Otherwise, we're all just WAG'ing at this point.
Check the actual engine temp w/a temp gun, and verify correct operation of the temp sensor/sending unit.
Couple questions:
- does the car have the boost fan? in front of the rad you can see it if you look up from the front of the far
- what color is the coolant?
- have you ever observed the coolant level in the overflow being "sucked back in" after the car is shut off and cools?
I see no reason to do anything other than rent or buy a cheap cooling system pressure tester. I got one off amazon for like 30 bucks and it does pretty much any type of cooling system.
Furthermore, it is entirely possible that you have a perforation in your cooling system that is *not* the head gasket. In L98's you can leak pressure / vacuum out of the intake manifold base gasket (common) and many other places. Doesn't have to be the head gasket.
Bubbling in the overflow is a significant clue. However that in an of itself doesn't point to only head gasket. You can either have a system filled with air due to a vacuum leak somewhere not allowing the fluid to be sucked back into the rad upon cool down (vacuum instead draws air into cooling system, while fluid stays in overflow, commonly found when hose to overflow tank has small cracks!). This results in perpetual air pockets in the cooling system. which then boils out, and system cooling capacity is reduced. when the system pressurizes again the air pockets will be forced out past the rad cap. its a negative downward spiral. gets worse with every heat cycle. or, like the mechanic likely deduced, you can have pressure leaking into the cooling plumbing via a perforated head gasket or crack in the cooling jacket wall, overcoming the 16psi cap that you have installed on your rad, and then escaping out the overflow. You need to figure out which one of those two reasons you have bubbling in the overflow.
I have had it 3 times on old c4 L98's. Once it was head gasket and twice it was simply cooling system allowing air back in and leaving fluid in the overflow. Once it was the overflow hose itself, and once it was the rearward intake manifold bolts were loose on bank 2.
Being a guy who has bought many c4 roaches i have dealt extensively with the L98 cooling systems. So far I would say we do not have a confirmation of head gasket issues.
Though if it was a mechanic who was uninterested in working on the car, if i saw bubbles in the overflow, i could quite easily see how that could be accepted as a diagnosis.
I am not saying he/she wasn't correct, but you can go through the motions and get a precise diagnosis.
Get a coolant system pressure tester. If you pressureize the system and cannot find any leaking/obvious areas where pressure is leaking, then install a cylinder pressurization hose (it looks like a compression tester, but the hose comes apart with an air fitting. you turn your air compressor down to about 35psi and you jam each cylinder full of air. be careful. the air will push that cylinder to bottom dead center. rotating the engine. watch your hands and chords. If you leave it and get bubbles out the overflow.....now you know you have a perforated head gasket, or cracked block. i've never seen the latter in an l98. pressurize from the back forward. Those two things (cooling jacket and cyl pressure) will tell you the story. I believe there was a suggestion of an exhaust gas detection system in the coolant upthread. this may cut through the bs and get straight to the diagnosis! I have never used one....but if you can know for sure you have exhaust gas in your coolant, you have your answer!
nice find on the car. even if it needs a head gasket job, that can be done for under $200 at home with basic tools! If you are handy, and yes, that includes decking the heads diy! or pay someone to do it if you have the cash.
Chances are it looks just like this
