Air pump eliminate?
Old Apr 25, 2022 | 03:43 PM
BLUDICE's Avatar
BLUDICE
Default Air pump eliminate?
So what’s involved with doing the air pump eliminate besides buying a $200 bracket.
Old Apr 25, 2022 | 03:59 PM
phaze426's Avatar
phaze426
You'll likely need a shorter serpentine belt as well. If your catalytic converter has the air inlet, you'll need to decide how you want to plug/cap it to prevent an exhaust leak there. Other than that, not too much other than fishing all the components out of the engine bay. I did this a few months ago with my son's 1990. Post with some detailed shots here:
https://www.corvetteforum.com/forums...post1604699628
Old Apr 25, 2022 | 04:47 PM
vader86's Avatar
vader86
The eliminator bracket doesn't need a shorter belt, it fits in place of the AIR.
You can leave the electrical connector hanging, and then use pipe plugs/caps to cover the AIR inlet on the exhaust manifold and main cat.
Old Apr 25, 2022 | 06:23 PM
captain vette's Avatar
captain vette
Why
Old Apr 25, 2022 | 07:16 PM
phaze426's Avatar
phaze426
I'm guessing it depends on the brand of eliminator kit. I did the TPIS kit. The instructions mentioned a few earlier years that would require a shorter belt and I didn't initially purchase one because 1990 wasn't one of those years. HOWEVER, the belt path with the pulley was definitely shorter than with the air pump in place and you can see in my pics where the tensioner bottomed out with the stock belt. Perhaps other kits better mimic the diameter and placement of the original air pump pulley.
Old Apr 25, 2022 | 07:42 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yep- make be gone. You and you car will not miss it. Buy the bracket and keep your belt. This is any easy, smart mod.
Old Apr 26, 2022 | 01:40 AM
yakmastermax's Avatar
yakmastermax
I used the cheap made in China Ebay kit the other week on my 1989. Fit fine with factory belt.
Spring for the TPIS kit if you can afford it though, support a good company.
Easy mod, should all just bolt on.
Old Apr 27, 2022 | 01:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
While watching Corvette Ben he simply opened up the air pump and removed the parts used to pump air.
Then you can remove all the AIR junk on the front of the engine and plug the old air inlets on the exhaust sustem.
To Air pump eliminate?
