1990 L98 Engine Vacuum Line Kit?
I am finishing up my intake manifold re-seal on my 1990 Corvette and I am in need of a few vacuum lines.
It seems that every vac line I touched on the manifold assembly broke when either removing, or reinstalling them.
I did a search of the web and didn't find any "kits", only generic vac lines and "t's".
Does anyone know of replacement OEM style prebent vac lines?
Thanks,
Tim in Mass
You can, however, get rubber or silicone vacuum lines that will slide over the hard plastic and connect them back up where they broke. This is what most of us do. Any Napa will have that.
I've been lucky enough to keep all of mine intact except for that EGR harness, which broke at the Y connector but then I was able to repair it back to original. I was lucky, but probably won't be that lucky again.
So I ordered up some replacement black plastic tubing from McMaster-Carr. It comes in multiple diameters, and I got the two most likely to work. When needed, it can be bent to shape using a heat gun carefully. Here are the part numbers and descriptions:
Hard Nylon Plastic Tubing for Air and Water
Opaque Black, 7/64" ID, 5/32" OD, 25 ft. Length
5548K82
Opaque Black, 9/64" ID, 3/16" OD, 25 ft. Length
5548K83
I pushed the rubber line over the hard line in the wiring harness going through the firewall.
Been doing fine for over a year now.
