Ignition Coil
Old May 15, 2022 | 07:43 PM
chocolatemilk1995's Avatar
chocolatemilk1995
8th Gear
Default Ignition Coil Removal - Help!
Hello,
I've been working to remove my Ignition coil on my 1993 Corvette LT1 & I've come across an issue when trying to remove it that I haven't found online.
As I try to remove my second bolt which is holding it in place - t seems like it's pushing my Power Steering Fluid container and I'm afraid it will harm something, I've actually included a video (linked below) explaining my problem more throughly.
So my two questions are:
- How do I remove this bolt without affecting the PS container?
- Does the Ignition Coil Also unplug like the ICM? I'm afraid to pull on the wires to harm it and am unsure how it unplugs?
I know these questions seem probably newbie-ish to most but I'm an admitted novice when it comes to working on cars but am doing my best to learn.
Video Explaining My problem removing bolt:
Last edited by chocolatemilk1995; May 15, 2022 at 07:59 PM. Reason: Hit enter too soon
Old May 16, 2022 | 05:37 AM
grandspt's Avatar
grandspt
It has been a long time since I replaced the coil and ICM. But there is another bolt way down under the power steering reservoir. If you remove it you can then move your reservoir out of the way and get easier access to the ICM and coil nuts/bolts.
Old May 16, 2022 | 08:31 AM
chocolatemilk1995
8th Gear
Thank you! I will look for this tonight!
To Ignition Coil
