Evap coil screen
Old May 16, 2022 | 05:45 PM
johnfin's Avatar
johnfin
Default Evap coil screen
My evap coil had a screen on one side. Do tge replacement units have these, should i use the old one or, just pitch it?
Old May 17, 2022 | 09:23 AM
syco_cop's Avatar
syco_cop
I would think the screen is to catch any charcoal that may work its way up from the evap canister. No screen will work fine till debris make its way to the solenoid.
Old May 18, 2022 | 07:02 AM
Deepa's Avatar
Deepa
My aftermarket coil doesn’t have a screen.
make sure you seal around the new coil so all of the air passes through it instead of bypassing it. Also make sure the evap housing is tight and sealed up. I used 3m strip caulk.
To Evap coil screen
