Ac compressor pressure cycle switch, 1984 corvette
Old May 17, 2022 | 10:17 AM
Hcredmon's Avatar
Hcredmon
5th Gear
Default Ac compressor pressure cycle switch, 1984 corvette
Hey, all I need to know is if this part:
https://www.ecklerscorvette.com/1984...-113591-1.html
will replace the oem compressor pressure cycling switch, which is located on the compressor line on the back of the ac compressor. Can’t find an oe replacement
Old May 19, 2022 | 11:18 AM
fparkin's Avatar
fparkin
Check Ebay They Have It
Old May 19, 2022 | 12:51 PM
Hcredmon's Avatar
Hcredmon
5th Gear
yes I see, but they are all used and 10x more as well.
Old May 19, 2022 | 02:43 PM
84 4+3's Avatar
84 4+3
To the best of my knowledge it is a high pressure cut out switch. It is a part that is no longer available from what I've found so your only option is used or to find a switch that has similar operating parameters and will thread onto the fitting and then you replace the connector on the harness. You'd be looking for something that opens at 400 psi +/- 20 and closes at 200 psi +/- 50. Mine appears to still function properly so I have left it alone though I did try to source a replacement when I rebuilt my HVAC system. That is as far as I got.
Edit: the one you linked I believe is for the low pressure circuit.
To Ac compressor pressure cycle switch, 1984 corvette
