Is it stuck in the up or down position? In either case put some silicon lube on the mast, or drip some on top if in the down position. Once it begins moving normally give the shaft a good polish and lube.
If the mast is broken internally you can find good vids on replacement.
not stuck I can move the mast up and down manually. Thank
