A/C Inoperative
Old May 20, 2022 | 01:49 PM
cash's90's Avatar
cash's90
Default A/C Inoperative
My A/C quit suddenly. Indicator light on controller is flashing indicating malfunction. Compressor clutch does not engage.
Steps taken so far-
Bypassed pressure switch, no clutch engagement.
Applied 12v to clutch and heard it engage.
Attached gage to low pressure port, started engine and applied 12v to clutch, observed pressure in mid green range.
A/C works with direct application of 12v directly to clutch.
Replaced A/C clutch relay. No joy.
Replaced secondary fan relay. No joy.
Tested for codes, no codes.
It appears that the signal from the control head to the clutch relay is being interrupted.
Please provide any suggestions you may have.
Old May 20, 2022 | 02:10 PM
topfuel67's Avatar
topfuel67
A couple of the common issues is the AC controller that is above the gas pedal has 2 capacitors that get hot and burn out. That same controller has vacuum lines going through the firewall and those get leaks. Since you say you have working air with the 12v applied directly, I would look at that controller.
Old May 20, 2022 | 03:03 PM
cash's90's Avatar
cash's90
Found a nice video on the Battee site describing removal of the controller. Thank You.
To A/C Inoperative
