The car sits slightly lower on drivers side - maybe 1”
is this perhaps from years & years of primarily being driven with only one person, in other words the spring has fatigued on drivers side ?
in any event can I adjust this by simply raising it about 1/2” on drivers side and lowering 1/2” on pax side by turning the nut in the appropriate direction on the bottom of the bolt ?
Doubtful it is the spring. How do the shocks look? Bushings? Yes, you can adjust the bolts on the rear to modify the height. Assuming all other things such as tires/wheels being correct.
C4 of Year Winner (appearance mods) 2019
Yep...Very easy to do. Did the same thing to mine (for the same reason) about 5 yrs ago. Been level ever since.
thx so much for replies.
Shocks are new. Bushings are ok but probably due for replacement in relative near future.
btw in meantime carefully measured difference : car sits 7/16” lower on drivers side.
question : any recommendations for adjustments? That is, lower pax side, or, raise drivers side, or, little of both ?
Well. shiver me timbers! And they said you can't teach "An old dog new tricks"! Thanks!!!!
Need to change oil pretty quick....Guess I'll have a look-see and try to lift the spring off the lower control arm -- to lube it per vid instruction. If you can lift the car to adjust springs, I'm guessing you can tackle this yourself. Sounds worthwhile....you know, to do once every 30 years! LOL
Huh. I wonder why GM didn't put a zerk in the underside of the arm to ease the greasing process?
Well? I'm probably going to go ahead and keep not lubing mine, but if you feel compelled to do it, a shop should. If you're asking, then you probably don't have a handy solution or plan to do it.
Let's see....that makes me 3 years overdue!
Think I’ll make it a Birthday present next March for her 40th!
How about every 40 years whether she needs it or not ?
I wonder if you jacked the spring up a smidgen, just room enough to slip in a thin piece of TEFLON would work !
