Tuning help
Old May 29, 2022 | 06:29 PM
Apedwards99's Avatar
Apedwards99
Default Tuning help
I got an ostrich 2.0 and put a $6E mask with an ARAR bin, it works alright but won’t start when hot and still seems off, idk how to tune yet either so I don’t know how to fix this. I have an 88 with a first TPI, stock fuel injectors 22lb, and long tube headers. Also a 160 t-stat. Is there a bin that won’t have any issue out of the box for this set up, do I need a different mask?
Old May 29, 2022 | 09:47 PM
tequilaboy's Avatar
tequilaboy
Got any scan data?
$6E bins have screwy crank fuel pw multiplier vs reference pulses. This could be part of the hard starting issue. Try setting 0.500 across the board. If it floods with 0.500, try 0.250 instead.
; CRANK FUEL PW MULT Vs. REF PULSE LT 17
; 10-18-1997 Dissassemby of ARAP Lines= 16
; TBL = 256 * MULT
ORG $038B ; MULT DRP'S
LC38B FCB 0 ; 0.000 1
LC38C FCB 0 ; 0.000 2
LC38D FCB 0 ; 0.000 3
LC38E FCB 0 ; 0.000 4
LC38F FCB 0 ; 0.000 5
LC390 FCB 0 ; 0.000 6
LC391 FCB 0 ; 0.000 7
LC392 FCB 0 ; 0.000 8
LC393 FCB 128 ; 0.500 9
LC394 FCB 128 ; 0.500 10
LC395 FCB 64 ; 0.250 11
LC396 FCB 64 ; 0.250 12
LC397 FCB 64 ; 0.250 13
LC398 FCB 64 ; 0.250 14
LC399 FCB 64 ; 0.250 15
LC39A FCB 64 ; 0.250 16
; CRANK FUEL PW MULT Vs. REF PULSE GT 17
; TBL = 256 * MULT
ORG $039B ; MULT DRP'S
LC39B FCB 51 ; 0.199 1
LC39C FCB 51 ; 0.199 2
LC39D FCB 51 ; 0.199 3
LC39E FCB 51 ; 0.199 4
LC39F FCB 51 ; 0.199 5
LC3A0 FCB 51 ; 0.199 6
LC3A1 FCB 51 ; 0.199 7
LC3A2 FCB 51 ; 0.199 8
Old May 29, 2022 | 10:54 PM
Apedwards99
Keeps saying error when I try to log, not sure why. But it’s cranking right up while hot right now. About to go on a long trip so it’s kinda scary to trust it
Old May 29, 2022 | 11:32 PM
Apedwards99
It was working, now it idles at 1400 and dies when it’s in gear
Old May 30, 2022 | 12:24 AM
tequilaboy's Avatar
tequilaboy
IAC might be out of sync.
Since you have an ostrich, you can easily force the IAC to open and close fully with the engine running by temporarily varying the desired idle rpm between extreme values (try something like 2000 rpm for 30 seconds or so, and then something like 400 rpm for another 30 seconds or so, then go back to normal settings).
Also after ign off, the IAC should go through a full cycle before setting to the start up position of 160 counts.
; IAC TARGET SPEED vs COOLANT TEMP
; Dissassemby of ARAP, LINES = 17
; TBL = .08 * RPM
ORG $052E ; RPM Deg c COOL
LC52E FCB 84 ; 1050 -40
LC52F FCB 84 ; 1050 -28
LC530 FCB 84 ; 1050 -16
LC531 FCB 84 ; 1050 -4
LC532 FCB 84 ; 1050 8
LC533 FCB 76 ; 950 20
LC534 FCB 72 ; 900 32
LC535 FCB 60 ; 750 44
LC536 FCB 48 ; 600 56
LC537 FCB 48 ; 600 68
LC538 FCB 46 ; 575 80
LC539 FCB 46 ; 575 92
LC53A FCB 46 ; 575 104
LC53B FCB 46 ; 575 116
LC53C FCB 46 ; 575 128
LC53D FCB 46 ; 575 140
LC53E FCB 46 ; 575 152
Old May 30, 2022 | 12:46 AM
Apedwards99
Checksum error, reuploaded the bin and it fixed with the same tune. Also this one has highway mode enabled so must be an Australian tune, I’ll take the extra mpg though
To Tuning help
