I have a 90 and need to replace both master and slave. do they still make or sell a whole assembly, or am i going to have to buy it in pieces with lines? Part numbers would help. the only thing i can find is 19 and 20 yr old threads in here.
Mine went out on my 92 right after I bought it in October 2021. I bought the one from Autozone with a lifetime warranty. I bought both the slave and the master. I only replaced the master and planned on getting to the slave. After I put the master on I pumped the clutch pedal several times and it got stiff. I have been driving it since with no issues. This was one of the easiest systems to bleed I have ever seen. My clutch disengages right at the first third of travel. I let the pedal out 2/3rds of the way before the the clutch engages from a stop so I know it is not too weak.
I also removed the seat to access it. It is so easy to remove the seat and gives you a great chance to vacuum under there. I also recovered a buck or two in change and some like new in the wrapper gum.
Only three pieces. Master, slave and if you want the clutch line. You would want the braided line which is the most expensive part… the master/slave cylinders are cheap. I went with Luk but I don’t think it matters much. Check rock auto for those, I think I got the line from zip corvette. It’s really easy to find the right parts via those sites.
Bench bleed the slave…then use the ranger method and it will bleed it no issue….
It’s an easy job just make sure to get the slave rod in the cup of the clutch fork when installing (yes I screwed that up somehow fussing with it).
Appreciate the feedback. I am very familiar with the hydraulic clutches in the lsx cars...been doing them since 97. Only had a few experiences with the older hydraulic with the push/pull slave. The problem isn't my clutch so much as i am losing fluid in the master reservoir about every 1-2 weeks. the lower bell housing is wet, so i think its the slave thats bad, but might as well replace both. i will be doing a clutch later this year (if i can help it) because the car has some miles on it and i don't know if its ever been replaced. feels like it may have, but not sure. this car will be my sons first and the last thing i want is for him to get stranded with no clutch. I am about to start the body work over the next couple of months as i get time and weather permits, so i'm just trying to get to the bottom of the missing fluid.
It's straightforward, replace all three pieces involved (slave, master, line[if original]). On these cars always do both cylinders together. It is common for the master cylinder to leak into the driver footwell (you would have wetness below where the pushrod goes through the firewall/damp carpet padding below), but it sounds like you may have found the primary leak at the slave...
As to the clutch, if it is working properly (not slipping and not chattering or shuddering badly) I'd leave it alone... Is there a reason you believe the clutch needs work (besides the hydraulics)?
No reason except for possible disk contamination from the leaking at the bellhousing. It will slip when down shifting to pass into 4th and 5th on the interstate, but that may be because of the lazy slave/master and low fluid. once i replace the hydraulics i will know more
I would not expect contamination from the hydraulic fluid...that should just run out of the bottom of the bellhousing without touching anything (unless it is squirting!). Further, leaking hydraulics should make it harder to shift and not affect clamping.
More likely worn out clutch (PP/disk) or oil/grease contamination (RMS or TO bearing that has thrown it's grease). Are you sure that the wetness is hydraulic fluid and not oil? If it's oil on the bellhousing inspection cover/part of the bellhousing closest to the front of the car, then it's very likely the RMS. You can always pull the inspection cover and take a look, also can use a scope through the slave hole in the bellhousing once you pull that to look around.
The hydraulics are easy enough, and you'll be doing them anyway if the clutch is blasted, so not a waste. Again, I'd still check the driver footwell as that is where my master was leaking.
How many miles?
Previous owner changed out the cluster which didn't help because the LCD and it all needs rebuilt again but originally I think it had around $110,000 on it and this cluster reads a little over 200,000 so I'm thinking of getting close to needing a clutch either way. I'm pretty sure it's not the rear main seal this looks like hydraulic fluid I've been a Master mechanic since I was in my mid-20s and I'm 47 now. I think somebody at some points been through this motor it's just some of it's in really nice shape and like the intake a whole bunch of bolts were stripped and messed up I had to cut heads off and pull them out of the intake just it was a mess. But it doesn't use a drop of oil it doesn't smoke at all however I'm worried about my head gasket I'm afraid to flush it so I may drain it just change the fluid right now till I can pull the motor later this year when it cools down in the fall.
The odometer reading is stored in the CCM, not in the cluster. When you change the cluster, the odometer reading remains the same on the new cluster. When you change the CCM, the odometer reading will be what is stored in the CCM from the car it was previously installed in.
Well the ECM looks like it's out of something else as well you know how you got salvage markings on them when you buy parts used... And so did the cluster from the back when I took it out I haven't gotten the CCM out of the car yet but that's my next project. I've got to do a rebuild on the DIC in the cluster and when I do all that I'm going to pull all the stuff out of the center of the console pull the carpet out as well. I'm really not sure what's been done this was a project from somebody else and he was a second or third owner I believe
Are you sure on this? Not trying to start an online argument, but I was surprised on my 01 Tahoe I found out it is stored in the cluster. I changed the cluster because it had some bad gauges. It had 177k miles on it. When I put in a cluster from the wrecking yard it showed 140k.
90 Corvette and a 2001 Tahoe or two completely different technologies. He is very correct your 01 Tahoe the cluster stores the mileage the ECU and BCM and the cluster have different functionalities in the 2001. In the '80s and '90s we still use prom chips and everything was still organized a lot differently in the computer systems.
